Go to Post FIRST does have instant replay. Its called the off season. - Wayne C. [more]
Unread 02-01-2017, 18:17
TylerS's Avatar
TylerS TylerS is offline
AKA: Tyler Stark
TylerS will become famous soon enough
pic: 1747 2017 Prototype Drivetrain Relesase
Unread 03-01-2017, 03:01
Re: pic: 1747 2017 Prototype Drivetrain Relesase
Connect the top flanges for the two pieces of sheet in the side rails. That'll make it massively stronger. Box sections = good. You can then cut lightening and access holes back in. We cut square holes in the top and bottom to make it easy to access and save weight.
Unread 03-01-2017, 20:42
Basel A's Avatar
Basel A Basel A is offline
It's pronounced Basl with a soft s
AKA: @BaselThe2nd
FRC #3322 (Eagle Imperium)
Basel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond repute
How would you suggest lining up holes on both sides of such a side rail? Cut the hole in one side and drill through the other side? Cut holes in both and do the bends really accurately?
Team 2337 | 2009-2012 | Student
Team 3322 | 2014-Present | College Student
“Be excellent in everything you do and the results will just happen.”
-Paul Copioli
Unread 03-01-2017, 23:09
tickspe15's Avatar
Purdue University
AKA: Spencer Tickman
We've considered connecting the top flanges in the past but werent sure if our sheet metal sponsor would be able to make the bend.
Team 1318: 2011-2015
Team 1747: 2015-Present
NAR (VEX U): 2015-Present
Unread 03-01-2017, 23:47
Ours can, so I imagine yours can. Our shops are awesome, but not specialty shops. They can use a goose-neck die. It's pretty common. Keep the L/D ratio not too crazy. 1 to 1 is easy.
For lining the holes up, as long as you use precision equipment, and take all the necessary precautions, the holes will be within 0.01". Plenty good.
Unread Yesterday, 00:25
Mike Schreiber's Avatar
FRC #0067 (The HOT Team)
We bend our own by hand and can't hold that accuracy. If we put a top brace on to box everything in we'll water jet that plate with rivet holes and match drill into the flanges of the side plates. It never lines up with everything perfectly, but it certainly does the job.
Mike Schreiber
