Go to Post Some people need the 2x4. - Ether [more]
Unread 05-01-2017, 12:12
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: pic: Team 4499's off season gearbox
Originally Posted by Michael 4499 View Post
Currently, the reasoning for the middle constraint is because there is an e-clip on the other side of the bearing.
Do I correctly understand that you are transmitting torque through an e-clip groove? If so, that's going to be a weak spot in your drive train. Putting an e-clip between the load-bearing gears and the future encoder should be OK, and between the gears and the end bearings would not be as good as the outside, but much better than between the gears transmitting torque to/from the shaft.
