Go to Post it's not the bot that makes the team great, it's the team that makes the bot great. - alicen [more]
Unread 05-01-2017, 12:59
Michael 4499 Michael 4499 is offline
FRC #4499 (The Highlanders)
Michael 4499 is on a distinguished road
Re: pic: Team 4499's off season gearbox
Do I correctly understand that you are transmitting torque through an e-clip groove? If so, that's going to be a weak spot in your drive train. Putting an e-clip between the load-bearing gears and the future encoder should be OK, and between the gears and the end bearings would not be as good as the outside, but much better than between the gears transmitting torque to/from the shaft.
Great idea, I think I can see a few changes that we can make to the gearbox to incorporate this.
Putting an E-clip between loads on a shaft is often a dangerous idea. It weakens the shaft substantially when something like a spacer could do the same job. I would just use a spacer between the two gears (that goes through where the bearing is currently located) and then put your encoder on one of the outer ends of that shaft.
Thanks for the suggestion, we will look into implementing it.
2016 Galileo & Carson - Gracious Professionalism
2016 Colorado - Chairman's award, Finalists
2016 Arizona North - Engineering Inspiration
