Go to Post The bleachers at a FIRST competition should be full of people blasting energy out of every pore of their bodies. - dlavery [more]
Unread 07-01-2017, 20:48
FRC #0234 (Cyber Blue)
Rookie Year: 1942
paper: Cyber Blue FRC 234 - Pneumatics Comparison
Cyber Blue FRC 234 - Pneumatics Comparison by Chris Fultz
Unread 07-01-2017, 20:50
Rookie Year: 1942
Re: paper: Cyber Blue FRC 234 - Pneumatics Comparison
Cyber Blue completed a mini design experiment during the summer and fall of 2016 to use some new lightweight components in the pneumatic system. All parts used are off-the-shelf components and meet the requirements of FRC.
We found the new components (Nitra) met our performance expectations and provided a significant (almost 1 pound) weight savings.
This report as completed by one of our students and mentors to document what was done and the results.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
Unread 09-01-2017, 07:24
only1chip's Avatar
only1chip only1chip is offline
AKA: Chip McDaniel
only1chip will become famous soon enough
Thanks for posting this paper team 234!
I wanted to follow-up with a link to the Automation Direct website showing where to purchase these new lighter-weight, less-expensive NITRA pneumatic parts:
Special Purpose Push-to-connect Fittings
Accessories
And don't forget that each team has a $35 voucher from AutomationDirect.com for 2017, so several of those parts could be yours for FREE ($6 flat-rate shipping not included). We also sell about 15,000 other industrial automation products, many of which could also be useful on your 'bot.
Good luck with Steamworks!
Unread 09-01-2017, 12:21
ngreen ngreen is offline
AKA: Nelson Green
FRC #1108 (Panther Robotics)
ngreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant future
With space at a premium again this year, this would be a nice change over the wonky brass fitting apparatus. The weight reduction is nice too!
Unread 09-01-2017, 15:57
s-neff's Avatar
s-neff s-neff is offline
AKA: Sam
FRC #0841 (Biomechs)
s-neff is a name known to alls-neff is a name known to alls-neff is a name known to alls-neff is a name known to alls-neff is a name known to alls-neff is a name known to all
Hi Chris,
Fascinating work. I'm concerned - does this meet R83b?
Originally Posted by R83b
...items are required...
B. Pressure relieve valve (per R82-C) connected via legal rigid fittings (eg brass, nylon, etc)
Or is the pressure relief valve just sitting "upstream" of this system?
Fun:
Mentor - Team 841 (2015 - ? )
Mentor - Team 4 (2013 - 2014)
Student - Team 192 (2009 - 2010)
Work:
SunPower Systems, Product Engineering - Utility Power Plants (2015 - ? )
BSci, Mechanical Engineering, UCLA (2010-2015)
Unread 09-01-2017, 16:07
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is online now
Registered Muser
Cothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond repute
Awesome work! I'm a big fan of PTC fittings, though sometimes barbed fittings are more compact. I do have a question though. I've had issues with accidentally crimping the narrower diameters of tubing during installation, and after they've been crimped once, they tend to keep doing it and restricting the airflow. Did you have any issues with that, especially on the U-turns seen in your example setup? And do you have any solutions for it?
Unread 09-01-2017, 16:54
Rookie Year: 1942
I believe the pressure relieve valve referenced is the one that will automatically vent if pressure gets too high. It is mounted on the compressor and was not part of our project since it would not change with either choice of parts.
Chris Fultz
Unread 09-01-2017, 17:00
rfolea's Avatar
rfolea rfolea is offline
AKA: Rick Folea
no team (Forsyth Alliance)
rfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant future
The U-Tubes shown in the paper are designed specifically for that purpose. Check it out here:
