Go to Post Do whatever you must to survive within the rules, but please stay within the rules. - Kevin Sevcik [more]
Unread 19-04-2003, 22:42
Gadget470's Avatar
Gadget470 Gadget470 is offline
A Fire Outside
AKA: Brandon Joerges
no team (Alpha Omega)
Gadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the rough
Send a message via ICQ to Gadget470 Send a message via AIM to Gadget470
Chewy: 'da Bears, team 247, did not have anything similar to Team 45's Ball Drive robot.
247 had 3 wheels (much like last year), and used 3 motors. The drills and a chiaphua with matched speed. Also, in each of the 3 they had an on-the-fly shifter. A fourth motor, which I believe was a globe, drove the rotation mechanism.
Basically put, on 247's bot, the wheels and motors all spun around to provide "omnidirectional" movement. In 45's secondary bot, everything stays stationary and the direction the ball is spun dictates it's movement. As probably stated in the other thread, the movement of the ball is based on how the two motors are moving. If you look at the ball picture, you can see how it has to axes of movement giving it omnidirectional movement from a standstill.
PM me if you would like a further explination of either system.
You can see two of 247's wheels (along with their suction system) in this picture:
