Re: pic: OMNI Drive
Originally Posted by pribusin
How do you figure? Aren't you always losing some forward vector from all four wheels due to all rollers being angled and only part of the rotational vector getting translated into forward motion? I'll give you that you have four wheels propelling rather than two.
You get v1/(2)^1/2 + v2/(2)^1/2=vd, assuming v1=v2, then vd=sqrt(2)*v1
That is to say: the diagonal speed will be ~140% of either pair of wheels' speed.
See:
I imagine that this drive base would be quite tippy given the small base of support. The setup below is more common because the base of support is larger, and the fastest drive speeds are now aligned with the major faces of the chassis.
Reason: Added a thought....
