Go to Post You have to admit, Regionals are pretty strange places, albiet cool - Otaku [more]
Unread 11-01-2017, 13:16
GeeTwo's Avatar
GeeTwo GeeTwo is online now
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: pic: OMNI Drive
If you keep the wheels in the same locations but rotate the chassis 45 degrees (or vice versa), you get what is sometimes referred to as Killough Drive (edit: pictured in post#7). This eliminates (or at least greatly reduces the "tippiness" at the corners. It is also kinematically the same as mecanum.
Unread 11-01-2017, 13:30
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: pic: OMNI Drive
Not.
Mec fwd/reverse kinematics is same as standard wheel.
Unread 11-01-2017, 13:49
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Re: pic: OMNI Drive
Not.
You do have to gear the Killough Mecanum ~40% faster to get the same behavior. I should have said similar (same shape, different scale).
I'm not sure what you're saying here. What sort of standard wheel?
Unread 11-01-2017, 16:53
Ether's Avatar
Rookie Year: 1969
Re: pic: OMNI Drive
omni vs mecanum vs standard wheel chart
Unread 11-01-2017, 17:21
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: pic: OMNI Drive
While each wheel has different kinematics between Omni and mecnanum, as a 4-wheeled system they behave the same. You just swap the "diagonal" behavior in one system for the cardinal directions in the other.
You do have to gear the Killough ~40% faster to get the same behavior. I should have said similar (same shape, different scale).
How do you figure.
Unread 11-01-2017, 18:09
jaweth12@gmail jaweth12@gmail is offline
FRC #0456
jaweth12@gmail has a little shameless behaviour in the past
Re: pic: OMNI Drive
Check this pdf on page 12
http://www.simbotics.org/files/pdf/drivetraindesign.pdf
Unread 11-01-2017, 22:04
OZ_341's Avatar Unsung FIRST Hero
OZ_341 OZ_341 is offline
#0341 (Wissahickon)
OZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond repute
Re: pic: OMNI Drive
Team 341 did a variation of this in 2007 and 2008.
However, we placed the wheels at the corners.
Our nickname for this configuration was "Z-drive".
If you do this, you have to be resigned to the fact that everyone can push you around at will.
We were OK playing a "run and gun" game in 2007. It allowed us to always face the goal with the tubes and just drive sideways. Then in 2008 you were not allowed to contact each other, so we did not have to worry about defenders.
We won the Philly Regional with this drive configuration in those two years.
That being said, it has a limited range of uses for most games.
2010 Championship Chairman's Award
2016 MAR District Champion (thank you 225 & 1257)
2016 Galileo Division, #6 Seed, 9 W - 1 L
2016 MAR District Innovation in Controls Award
2016 Westtown District Finalist (thank you 4954 & 484)
2016 Westtown District Imagery Award (It took 17 yrs)
2016 Hatboro District Judge's Award
Overall Record 49 W - 21 L
Unread 12-01-2017, 09:09
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Re: pic: OMNI Drive
Originally Posted by Lil' Lavery View Post
How do you figure.
Ether answered in the previous post. √2 - 1 =~ 40%.
Edit: As I look at Ether's chart, mecanum should be 40% faster, or omni 30% slower.
And thanks for keeping us honest, Ether!
Unread 13-01-2017, 01:31
pmattin5459 pmattin5459 is offline
AKA: Patrick Mattin
FRC #5459 (Ipswich TIGERS)
Rookie Year: 2015
pmattin5459 will become famous soon enoughpmattin5459 will become famous soon enough
Re: pic: OMNI Drive
If you haven't built a holonomic drivetrain before, don't design one in the middle of build season. Just use a tank drive. If you're really set on it, then i would suggest mecanums, which can be added to a standard chassis fairly easily, or, if you really want the omnis, put them in the corners diagonally.
