Go to Post This is the best experience you will ever get. - Arefin Bari [more]
Unread 15-01-2017, 17:24
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
pic: 2017 Davit close up
Unread 15-01-2017, 17:26
cad321 cad321 is offline
AKA: Brian Wagg
FRC #2386 (Trojans)
Re: pic: 2017 Davit close up
Close up of the Davit. Note that the steel channel is flash with the bottom of the plate. You'll probably need something to the side of your winch to actually trigger the plate.
I'll be curious to see how many teams show up to competition with no clue that this existed. You would have thought something such as this would have been included in the team drawings. Guess we're going to have to make a revision to our team version Davit.
Unread 15-01-2017, 17:29
JR0405's Avatar
JR0405 JR0405 is offline
Electrical & Pneumatics/Mechanical
AKA: Jack Ross
FRC #5822 (Wolfbyte)
JR0405 is a name known to allJR0405 is a name known to allJR0405 is a name known to allJR0405 is a name known to allJR0405 is a name known to allJR0405 is a name known to all
FIRST doesn't even hint of this in the field tour video
#StaySavage
Unread 15-01-2017, 17:30
Ty Tremblay's Avatar
Robotics Engineer
FRC #0319 (Big Bad Bob)
Here's an album of pictures and video 319 took at the real field in NH last Saturday. We also revealed a compilation video on check_in.
https://goo.gl/photos/zvfDz4shmR9QqGXh7
Unread 15-01-2017, 17:33
chapman1's Avatar
chapman1 chapman1 is offline
FRC #3688 (Suttons Bay Norsemen Robotics)
chapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond repute
Thanks, I missed that.
Older, but still somewhat coherent.
Unread 15-01-2017, 19:29
mmaunu's Avatar
mmaunu mmaunu is online now
FRC #2485 (W.A.R. Lords)
mmaunu is a jewel in the roughmmaunu is a jewel in the roughmmaunu is a jewel in the roughmmaunu is a jewel in the rough
I'm not trying to be rude (and certainly not trying to be clueless...that typically happens with no effort on my part) but I don't understand what you are trying to show here. I get that it is important (based on the reactions) but the image does not illustrate your point clearly. Please help as you now have me concerned and I get the impression that the detail(s) are important here. Thanks!
2014 Las Vegas (Winners with 987, 2478; Excellence in Engineering)
2014 San Diego (Finalists with 987, 3250; Quality Award)
2013 Inland Empire (Winners with 1538, 968; Excellence in Engineering Award)
2013 San Diego (Finalists with 2984, 4322; Creativity Award)
2012 Las Vegas (Finalists with 2034, 3187; Quality Award)
Unread 15-01-2017, 19:30
JR0405's Avatar
AKA: Jack Ross
When a robot climbs the rope it can't just keep climbing and have something flat hit the platform because it will hit the metal and won't offset the plate if that makes sense
#StaySavage
Unread 15-01-2017, 19:33
MARS_James's Avatar
MARS_James MARS_James is offline
Always Scouting
AKA: James Comstock
FRC #0179 (The Children of The Swamp)
Team Role: Tactician
MARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond repute
Send a message via AIM to MARS_James
If you look there is a metal channel through the middle of the touch pad that doesn't move when it is pressured. You can see it pretty clearly here thanks to 319 for the picture. This means that if you are climbing the rope straight up you may not be able to initiate the sensor since you will collide with the channel
Driving Record: 24-8
Coaching Record: 66-31
2014 South Florida Regional Woodie Flowers Finalist
Unread 15-01-2017, 19:45
Apologies for the picture, it was the best I could get out of my phone. Looks like ty has a better one:the point is that gold piece is flush with the bottom of the lexan plate you have to raise. Most of the drum and winch lifts I've seen posted will probably hit that metal channel before they move the lexan enough to trigger it.
Unread 15-01-2017, 19:46
JR0405's Avatar
AKA: Jack Ross
Apologies for the picture, it was the best I could get out of my phone. Looks like the has a better one: the point is that gold piece is flush with the bottom of the lexan plate you have to raise. Most of the drum and winch lifts I've seen posted will probably hit that metal channel before they move the lexan enough to trigger it.
Pictures broken
#StaySavage
Unread 15-01-2017, 21:11
Aphit Aphit is offline
FRC #2080 (Torbotics)
Rookie Year: 2017
Aphit is an unknown quantity at this point
Great find. I know our team wasn't aware of this, and we will likely be adjusting/tweaking design accordingly.
Thanks!
Unread 16-01-2017, 15:41
Ed Sparks Ed Sparks is offline
Engineer/Mentor/Inspector
AKA: FirstCadLibrary Guy, Inspector Dude
FRC #3959 (Formally with FRC-34)
Ed Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond repute
Send a message via AIM to Ed Sparks Send a message via Yahoo to Ed Sparks
Another Pic .....
https://www.chiefdelphi.com/media/photos/44127?
Ed Sparks
MECH TECH FRC-3959
Unread 16-01-2017, 15:46
FIRST needs to release a Field Tour video including this, or add this to the Team Drawings, or point it out in a Team Update, or SOMETHING to draw attention to this. This is a giant design hurdle that is far too subtle to be noticed by teams that aren't in the know.
Unread 16-01-2017, 18:15
Sooner73 Sooner73 is offline
FRC #2881
Sooner73 is an unknown quantity at this point
Could be a huge problem!
Thanks to all for the pics
Unread 16-01-2017, 20:20
jaunvie jaunvie is offline
FRC #5090
jaunvie is an unknown quantity at this point
The pics were awesome. Thanks so much. I was wondering about a few things and it's nice to see pics of the actual field. Form those of us who can't see a real field, Thank you so much!
