Go to Post Well, there goes our bare aluminum corner tracking full field navigation system... - Whippet [more]
Unread 16-01-2017, 21:05
Crew Cox's Avatar
Crew Cox Crew Cox is offline
Electrical team Captain
FRC #5546 (A.R.T)
Crew Cox is a jewel in the roughCrew Cox is a jewel in the roughCrew Cox is a jewel in the rough
Intake Conveyor Ideal Speed
Hello all and thanks for reading.
For our fuel intake and shooter feed-conveyor we will likely be using 1 1/2 in. Aluminum rollers and 1 inch wide orange belting from McMaster Carr.
We will also likely be using a 775 pro with a versaplanetary to power both.
This said, does anyone have a approximate ideal spead for the belts to be moving?
Unread 16-01-2017, 21:09
Skyehawk's Avatar
Skyehawk Skyehawk is offline
Nuts N' Bolts
AKA: Skye Leake
FRC #0876 (Thunder Robotics)
Skyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to all
Re: Intake Conveyor Ideal Speed
Mach 10
My time in FIRST has made me a better person, frankly I don't know where I'd be without it.
2011 Lake Superior Regional Champs (Thanks 2512 & 3747)
2015 Central Illinois Regional Engineering Inspiration Award recipients
2016 Central Illinois Regional Champs (Thanks 2481 & 2220)
Unread 16-01-2017, 21:10
EricH EricH is offline
Originally Posted by Skyehawk View Post
Mach 10
Still too slow.
In seriousness, I would suggest prototyping. In this case, I'd grab a cordless drill and use it on the drive of the intake to see what is likely to work.
Unread 16-01-2017, 21:12
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
you want the linear speed of your intake to be faster that you can drive forward. One of my build members, now an alum, has a rule of thumb that it should be twice as fast as your drive. Once you get it there, you can tweak it to suit your needs.
Crew Cox's Avatar
FRC #5546 (A.R.T)
So what I'm getting is fast as possible without;
Breaking/slipping a belt
Burning up/ stalling a motor
Obtaining liftoff?
Unread 16-01-2017, 21:13
Skyehawk's Avatar
Nuts N' Bolts
AKA: Skye Leake
It is difficult to know without seeing your design, and even then the land of theory does not translate perfectly to the real world. As far as prototyping goes 400-800rpm should pull that fuel off the floor like a hot d*mn...
Unread 16-01-2017, 21:14
Crew Cox's Avatar
FRC #5546 (A.R.T)
Thanks! Duly noted
Unread 16-01-2017, 21:15
engunneer's Avatar
engunneer engunneer is offline
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
engunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond repute
basically.
I'd aim for 1.25x robot's top speed. Also, a 775pro is likely overkill. I'd probably start with a bag motor first, and if i don't get the power i want move up to some other banebots options. though if you are using lots of 775 pros and want to maintain interchangable spares, it's not a bad plan.
Student FRC23 (1996-1999), Mentor FRC246 (2000), Mentor FRC1318 (2007-2009), Mentor FRC93 (2011), Mentor FRC2151 (2012), Mentor FRC23 (2013), Mentor FRC4761 (2014-2017)
1998 - National Chairman's Award and Woodie Flowers Award (FRC23, Mike Bastoni ) | 2007 - PNW SF (488, 1595) | 2008 - Oregon RCA - Seattle #2 Seed, SF (488, 1696) | 2009 - Oregon #1 Seed, Winners (1983, 2635) - Seattle SF (945, 2865) - Galileo #2 Seed, SF (973, 25) | 2012 Midwest F (111, 71) | 2014 RIDE Winners (78, 125), Inspector - NEU #24, QF (3479, 3958) - NECMP #35 | 2015 Reading #11, SF (1058, 190), Inspector - RIDE #17, QF(4055, 5494), Inspector - NECMP #57 | 2016 Reading #4, SF (133, 4474), DCA, Inspector - Ride #22, SF (1735, 2067), Creativity, Inspector - NECMP #48, RCA - Archimedes
Unread 16-01-2017, 21:18
Crew Cox's Avatar
FRC #5546 (A.R.T)
Originally Posted by engunneer View Post
basically.
This was the idea. Same reason for (hopefully) using the same ratio for both conveyors.
Unread 16-01-2017, 21:19
cadandcookies's Avatar
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
basically.
A general rule for intakes, I've found, is to give them as much power as you can spare. With modern FRC motor rules, there isn't really anything holding this back other than how much your motors are drawing (over the course of a match and when considering the draw of all your motors running simultaneously). Without looking at the final design being suggested, while I might say a 775pro sounds like overkill, it is possible that it's what is necessary.
You intake should command that the game pieces it touches enter your robot, not lightly suggest that they do.
tumblr | twitter
VEXU UMN (2015-??)
Volunteer since 2011
Unread 16-01-2017, 21:23
Crew Cox's Avatar
FRC #5546 (A.R.T)
This is now my favorite quote.
Thank you.
Unread 16-01-2017, 21:25
RoboChair's Avatar
AKA: Devin Castellucci
+1 Touch it. OWN it.
Obtaining liftoff?
Liftoff is fine, encouraged even.
We like our intakes going over 1000 RPM. Sometimes even faster, time waiting to intake is time you are not scoring. Touch it. OWN it.
11 Years and counting! Over a third of my life has been spent with FRC.
Unread 16-01-2017, 22:08
Munchskull's Avatar
Munchskull Munchskull is offline
AKA: Anthony Cardinali
FRC #0997 (Spartan Robotics)
Munchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to behold
3500 RPM too fast?
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 16-01-2017, 22:11
RoboChair's Avatar
Originally Posted by Munchskull View Post
3500 RPM too fast?
You will have to test it and make sure it won't stall out, but it just depends on your surface speed requirements.
Unread 17-01-2017, 10:22
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
I second the recommendation for AT LEAST 2x robot speed. The reason being that if the top of a ball is moving at 2x robot speed, the cewnter of the ball will move at 1x robot speed while the bottome of the ball touches the ground. Thus the FUEL will get get pulled into the robot significantly faster than the robot can drive.
The FUEL won't get knocked away and the robot won't jam the FUEL into its own intake with forward inertia. Perhaps most importantly in this year: if the robot interacts with a sea of game elements it won't push the bulk of FUEL away as it collects FUEL on the perimeter of that sea.
Strongly recommend the highest powered motor(s) you can stand for the application, even if you run it on an under-sized breaker (like a 775 pro on a 30A circuit). No one has ever said 'my intake can collect [game element] too quickly.' More to the point: the faster you can collect FUEL/GEARs/whatever the more time you have to score it, and there are fewer things more painful to a scout than watching a team spend time collecting game element.
My $0.02 anyway...
