Go to Post Education is important, but for some, FIRST is their education. - Sam Lipscomb [more]
Unread 21-01-2017, 20:24
AriMindell AriMindell is offline
FRC #1389 (The Body Electric)
Rookie Year: 2015
AriMindell will become famous soon enoughAriMindell will become famous soon enough
pic: Retro-reflective rope detection - GRIP
Unread 21-01-2017, 20:25
Rookie Year: 2015
Re: pic: Retro-reflective rope detection - GRIP
Thoughts on whether this is viable/useful? our plan is to use it to align with the less visible davits - the ones facing into away from the driver stations.
Unread 21-01-2017, 20:35
NShep98's Avatar
NShep98 NShep98 is online now
AKA: Nathan Shepherd
FRC #2079 (4H ALARM Robotics)
Rookie Year: 2015
NShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud of
I certainly don't see why this would not be useful. As long as it is a legal rope, I would consider this a clever approach to climbing. Odds are the rope is not going to fall straight down. There will likely be some sort of curve to it. To be able to account for this, especially if your rope is not clearly visible, seems very helpful.
FRC 2079 - 4H ALARM Robotics 2015 - 2017
FLL 2011, 2013
Unread 21-01-2017, 20:46
dirtbikerxz's Avatar
dirtbikerxz dirtbikerxz is offline
Captain | Driver | CAD | Junior
AKA: Rohit Gondi
FRC #3991 (KnightVision)
Rookie Year: 2015
dirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud of
While this is definitely a cool idea, I don't see why your rope would not be visible. If you setup up your rope in the davit that is right in front of you station, it should be pretty visible. And i don't see any reason why your alliance partners would not let you setup your rope right in front of your station.
Team 3991: Driver since freshman (2015-), Captain since sophomore (2016-), CADer
"The human condition is not perfect. We are not perfect specimens, any of us. We're not robots." - Michael Ovitz
My posts may or may not reflect the views of my team, they are my opinions, and mine alone.
Unread 21-01-2017, 20:52
Rookie Year: 2015
Given the high point value and low difficulty of rope climbing (compared to climbing in previous years at least) I would expect almost every elminations alliance to have 2-3 climbers at the higher levels of competition. Once you have more than one, someone has to take one of the rear davits
Unread 23-01-2017, 14:37
flemdogmillion's Avatar
flemdogmillion flemdogmillion is offline
Programmer, Builder, Driver...
FRC #3007
Rookie Year: 2015
flemdogmillion will become famous soon enoughflemdogmillion will become famous soon enough
Retro-reflection requires glass (or other RI-specific transparent material) beads typically, either that or metallic/mirrored surfaces, which are not fibers. I am worried that a retro-reflective rope does not abide by the rules.
Unread 23-01-2017, 14:48
GeeTwo's Avatar
GeeTwo GeeTwo is online now
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
If retro-reflective rope is out (TBD), I'd recommend selecting a rope in a color that is not otherwise going to be in the view area, and doing some color filtering before passing an image to your rope finder, or some way to take advantage of parallax.
Unread 23-01-2017, 14:59
ahartnet's Avatar
ahartnet ahartnet is offline
AKA: Andrew Hartnett
FRC #5414 (Pearadox)
ahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond repute
I am not an inspector, but I would have a hard time considering a rope with "retroreflective filaments" to be a rope. When I think of light bulb filaments (or any other filament), it may be thread-like/fiber-like, but it is still a metal. https://frc-qa.firstinspires.org/qa/...ery=reflective
All that said, I'm still not all that convinced the vision is that much more useful with lining up on the rear rope than just a normal camera without vision. You should still have a pretty good angle for the driver for the rear davits if your not in station 2. And if you're in station 2, you should have priority for the davit directly in front of you.
Team 451 The Cat Attack, Student Alumni (2005)
Team 1646 Precision Guessworks, Mentor (2006-2008)
Team 2936 Gatorzillas, Mentor (2011-2014)
Team 5414 Pearadox, Mentor (2015-Present)
Unread 23-01-2017, 23:24
staplemonx's Avatar
staplemonx staplemonx is offline
The Idea Guy
AKA: JJ Biel-Goebel
staplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond repute
http://searchgear.com/pmiretroreflectiverope.aspx
crazy engineer
www.jjbiel-goebel.com
helping team 1389
http://team1389.com/
Unread 24-01-2017, 09:33
FRC #3007
Rookie Year: 2015
Originally Posted by staplemonx View Post
Glass beads = not fibers = not allowed. As I feared.
Unread 24-01-2017, 10:05
Jon Stratis's Avatar
Jon Stratis Jon Stratis is online now
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
In this case, we even have a Q&A for it...
https://frc-qa.firstinspires.org/qa/51
There was some argument on CD. We could not figure out if glass beads in rope counted as "flexible" or "fiber".
No, glass beads are neither flexible nor a fiber.
2016: Lake Superior WFFA
Unread 26-01-2017, 16:22
Big Ideas Big Ideas is offline
AKA: Stephen des Jardins
FRC #2102 (Team Paradox)
Big Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant future
In all likely hood, for the ROPE shown, glass beads are added as a fillet to some of the rope FILAMENTS. If this holes true, then we need to inquire, for all ROPES, if there is ridged filler in the filaments. Possibilities are talc, mica, and various other minerals. Manufactures rarely publish this info in their standard literature. Likely an MSDA will not be helpful either, IF it exists. Alternately, give the inspectors a microscope and we will do our best.
IMHO if there is a thing called ROPE that is part of a standard product, made by a ROPE manufacturer then it meets the ROPE test. If there is to be a ban on GLASS beads, in any form, Just say so. Like, the ban on metal (in any form).
This is not to say that I think that a rope that has been processed (by the team or others) to glue glass beads to the surface would be legal.
