Re: pic: Toughbox Mini Bound Up On AM14U3 KoP Chassis
In this case the Tough box Mini housing would not set flush to the rail, so when the housing was tightened, the gear box bound up. The bearing was bottoming out in the bore with the hex bearing and output shaft gear correctly installed.
