Go to Post I like the way you are saving weight by cutting out the center of the speed controllers. - jcatt [more]
Unread 25-01-2017, 16:37
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: pic: Toughbox Mini Bound Up On AM14U3 KoP Chassis
Thanks for the heads up!
We had a TB-mini bind up near the end of build yesterday. We checked the obvious stuff like gears installed backwards (bosses together instead of at bearings), but not this. We just replaced the gearbox with one we had build for the second robot and moved on, and we'll look at the binding gearbox tomorrow. (no build today.) I'll be sure we check for this early in the process.
