Go to Post Such is life in the fast-paced, laugh-in-the-face-of-adversity, never-let-them-see-you-sweat, sometimes-you're-the-windshield-sometimes-you're-the-bug world of FIRST Robotics! - Sean Schuff [more]
Unread 01-02-2017, 06:50
The one with the punny last name
AKA: Daniel Koh
FRC #0299 (Valkyrie Robotics)
pic: CAD Crash World Record?
Unread 01-02-2017, 06:53
FrisbeeFunTime FrisbeeFunTime is offline
FRC #1768
Rookie Year: 2015
FrisbeeFunTime is an unknown quantity at this point
Re: pic: CAD Crash World Record?
Could you post the model also so that we could look at the other specs, it would make it easier for us to give you the best advice we can. Does SOLIDWORKS give you a specific error every time you crash or does it just close down? What models do you have open when it crashes?
Unread 01-02-2017, 07:54
Crebb's Avatar
Crebb Crebb is offline
AKA: James M.
FRC #5279 (Bionic Eagles)
Crebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud of
SolidWorks 2017 is a new release and fairly unstable. I typically don't upgrade to the current SolidWorks version until service pack 2 or 3 because of the stability issues. I believe service pack 1 recently came out so you could try upgrading to that and see if it helps.
SolidWorks will give you a popup message in the lower corner letting you know if you are running low on system resources. If you haven't been getting these messages then you are most likely crashing due to the program instability and not a lack of memory.
Save often!
Shibuya Hoppmann, Mechanical Engineer
VCU School of Engineering 2012
Team 5279 2016-Present
Team 384 2003-2015
Unread 01-02-2017, 08:17
Eric Scheuing's Avatar
FRC #0999 (MechaRAMS)
I'm assuming integrated graphics as well? If so, I wouldn't bother with the RAM and SSD investment, and just put it toward a new CAD machine instead.
2015-20XX: MechaRAMS 999
Unread 01-02-2017, 08:19
Sperkowsky's Avatar
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Generally the life cycle for a mid range laptop is 5 years. Looks like its time for you laptop's retirement.
Unread 01-02-2017, 08:23
Fields's Avatar
Fields Fields is offline
Classic
Rookie Year: 2015
Fields is a name known to allFields is a name known to allFields is a name known to allFields is a name known to allFields is a name known to allFields is a name known to all
As a safe rule of thumb, don't go to a new until service pack 3.
SP0 - Cool new features but LOTS of bugs
SP1 - big obvious bugs fixed
SP2 - big non-obvious bugs fixed
SP3 - small but annoying bugs fixed (also general user complaints are usually fixed here too)
10 years ago, crashes were just a fond way of life. [end_sarcasim]
In the engineering labs at our college, teams of 4 would be at each computer working on some assignment at 11 pm. Without fail, every night I was there, some team would yell as their computer crashed losing valuable work. Immediately, everyone else would stop what they were doing and save their work, even if they had just saved 5 min prior.
Sunsytems computers running I-DEAS. Good times.
Wait... you built what now?
Unread 01-02-2017, 09:54
It's probably too late to downgrade to 16 so giving the poster that advice isn't super useful.
That said, yes, an SSD and 8 GB of RAM will absolutely help. But that money might be better spent on a newer laptop - I feel like even many used 3-5 year old laptops you could get for reasonably cheap off Craigslist / Ebay would outperform a 2009 Dell laptop.
Unread 01-02-2017, 10:15
Mike Schreiber's Avatar
FRC #0067 (The HOT Team)
I'm running Solidworks 2015 on a SSD with 32 GB of RAM - the computer doesn't help the crashes. It's the service packs.
Mike Schreiber
Unread 01-02-2017, 11:28
frcguy's Avatar
frcguy frcguy is offline
#GearsAllDay
AKA: Nicholas Dal Porto
FRC #5940 (B.R.E.A.D.)
Team Role: Tactician
Plot twist: Daniel added so many Recycle Rush totes to 299's robot that the laptop just couldn't keep up anymore.
2017: Team 5940 (Silicon Valley Regional/San Francisco Regional)
Unread 01-02-2017, 11:46
OccamzRazor's Avatar
OccamzRazor OccamzRazor is offline
Go YETI!
AKA: Robbie
FRC #3506 (YETI)
OccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to behold
I use, teach, and run tech support for SOLIDWORKS every day and I recommend more than the current minimum which is 8 gigs of RAM, a supported graphics cards, and a SSD. If you can get more RAM then do so because RAM is cheap. As for the crashing itself you can usually help this by creating your assemblies for your robots in such a way that benefits your machine. And don't worry, everyone crashes from time to time no matter what CAD system you use so you are not alone.
There are a ton of ways to make your assemblies faster and easier to work with but the key is really how you put them together no matter which CAD software you use. I have a video here that describes how companies actually lose a ton of money because of poor assembly management and a couple of solutions to the problem which exist in the software. Large assemblies will lead to instability and crashes without some checks in place.
Check this video out and see if that helps before buying a new machine:
https://www.youtube.com/watch?v=Og6nYQ7k2Bw
Our full robot assembly rebuilds in under 10 seconds on student machines and that is because we only have 5 subassemblies in the top level. Most teams I see usually have hundreds of parts in one top level assembly. You can build the parts at the top level and drop them into subassemblies later. Just remember that having tons of mates, complex geometries, and tons of parts in the top level is usually what causes the crashing.
The most complicated parts on most robots are often the transmissions. We save those form a .step file from the manufacturer as a single solid or part because you only need what, 3-4 bolt holes? The rest is just a placeholder.
Hope this info helps!
2015 NC Regional Chairman's Award
2016 NC Guilford District Event Winner
2016 NC Guilford District Chairman's Award
2016 NC District Championship Winner
2016 NC Regional Chairman's Award
2016 NC Woodie Flowers Award Finalist - Lia Schwinghammer
Unread 01-02-2017, 11:48
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Going from 6-8 GB of RAM is such an incremental increase it'd be unlikely to lead to real performance gains. Imo you really need at least 16 GB if you're serious about CAD.
2001-2004: Team 100
2006-Present: Team 254
Unread 01-02-2017, 12:18
RoboChair's Avatar
AKA: Devin Castellucci
Remember folks.
Save Early, Save Often.
12 Years and counting! Over a third of my life has been spent with FRC.
Unread 01-02-2017, 12:51
FRC #1072 (Harker Robotics)
Solidworks crashes less the longer I've used it. Keep at it, it'll get better.
Also buy a nice computer. Get a job!
Unread 01-02-2017, 17:17
Michael Hill's Avatar
My SolidWorks Educational has been crashing like crazy. I have a Dell Precision M3800 with I believe a Quadro K1100M with SolidWorks approved drivers. Crashes seem to most often occur when SolidWorks models go transparent (hole wizard, mating, etc.) it's very annoying.
