Go to Post When a vomit shooter runs out of balls, is it dry heaving? :p - Lil' Lavery [more]
  #31   Spotlight this post!
Unread 01-02-2017, 16:11
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: pic: Spectrum 3847 - 2017 CAD Model: Gamma Ray
Originally Posted by EricLeifermann View Post
I don't know what we were spinning them at accurately but it was faster than 6000. The problem wasn't that the expansion was affecting the shots, its that I wasn't comfortable safety wise with the expansion. We were also using 2in roller over a 1.5 aluminum tube, so maybe the smaller diameter doesn't expand as much was we saw with the large.
Centrifugal acceleration* = w^2 * r. More RPMs and more radius = more force expanding your tube. Since this acceleration applies to all of the tube, thickness won't matter, aside from the smaller force on the ID of the tube. The only material property that matters is some sort of ratio of density and elastic modulus, but that'd be the same since ou said it was the same stuff.
So all in all, not surprising your tube wanted to expand more than Spectrum's. Are you guys going for a longer shot to need that much more surface speed?
*Yes centrifugal. Pedants are welcome to spend 15 minutes drawing a FBD with a tangential velocity, required change in velocity to create a circular path, implied acceleration, unbalanced force to create that acceleration, etc, etc. I'm going to pretend it's a real force and get on with my life.
  #32   Spotlight this post!
Unread 01-02-2017, 16:14
EricLeifermann's Avatar
EricLeifermann EricLeifermann is offline
That was a short break
FRC #2826 (Wave Robotics)
EricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond repute
No just limiting the contact time and wheel size, as well as bad prototypes and the mentality that we will be able to spin slower with a properly built robot that has less friction deficiencies.
2002-2005 Appleton East High School: Team 93
2005-2011 Michigan Technological University: Team 857
2012-Present Wave Robotics Team 2826
  #33   Spotlight this post!
Unread 01-02-2017, 17:16
Brian Selle's Avatar
Brian Selle Brian Selle is offline
Brian Selle has a spectacular aura aboutBrian Selle has a spectacular aura aboutBrian Selle has a spectacular aura about
Nice job 3847! What are the servo motors on the front/back of the shooter for?
2016 Curie Quarter-Finalist (5803, 3310, 2168, 5940), Lubbock Regional Winner (3310, 4063, 4301), Arkansas Regional Winner (16, 3310, 6055)
2015 Newton Quarter-Finalist (3130, 2468, 3310, 537), Lubbock Regional Winner (2468, 3310, 4799)
2014 Galileo Quarter-Finalist (2052, 70, 3310, 3360), Colorado Regional Winner (1138, 3310, 2543)
2013 Archimedes Semi-Finalist (126, 3310, 1756), Texas Robot Roundup Winner (3310, 624, 2848), Dallas Regional Winner (148, 3310, 4610)
2012 Dallas West Regional Winner (935, 3310, 4206)
  #34   Spotlight this post!
Unread 01-02-2017, 17:21
fresh_prince fresh_prince is offline
Not allowed to navigate or DJ
AKA: Will Smith
FRC #3847 (Spectrum)
Team Role: Student
fresh_prince is an unknown quantity at this point
Thanks! We'll only be using one of the two sets of three, but they're intended to be lane blockers. If we line up to the boiler and one of our side streams isn't on target, we want to be able to disable that stream instead of realigning our entire robot. We have one in the middle so that we can theoretically make a shot while our side is lined up with either the driver station or the front wall of the field.
AMDG, LTF
3847 - Spectrum | 2014-2017 | Student
  #35   Spotlight this post!
Unread 02-02-2017, 01:32
Joy4201 Joy4201 is offline
FRC #4201 (The Vitruvian Bots)
Rookie Year: 2016
Joy4201 is an unknown quantity at this point
This is so amazing!
My team and I just had a few questions:
What is your shooter compression and how did you settle upon this number?
What is your intake height and how did you find this number?
  #36   Spotlight this post!
Unread 02-02-2017, 03:34
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
Originally Posted by Joy4201 View Post
This is so amazing!
At the moment I believe it's around 4 5/8" between the drums but the tower includes two plates that can be changed to allow us to increase compression if we need too.
The height of the fixed intake roller is about 4.75" from the floor but that could also be changed by going to larger wheels. We currently have 1 5/8 compliant wheels from WCP but we could use 2" wheels if needed.
We wanted to design to the smallest amount of compression we could get to work and increase if needed. That way we start with the least load on the motors and add load as needed.
  #37   Spotlight this post!
Unread 02-02-2017, 14:19
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Great design! Ironically, just looking at your rather complex robot, I was inspired of a way to make our gear pickup MUCH simpler (replace two motors with one belt). Thanks!
  #38   Spotlight this post!
Unread 02-02-2017, 15:11
Bob Steele's Avatar
Professional Steamacrit Hunter
AKA: Bob Steele
Beautiful looking robot... and the CAD is nicely done.
I am looking forward to seeing how this plays on the field.
Well done!!
  #39   Spotlight this post!
Unread 02-02-2017, 15:50
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
Originally Posted by lukekaiser View Post
Agreed
Teams need to make sure they read all rules pertaining to robot size carefully. I would hate to see a robot this well designed get to a competition and then not pass inspection.
I'm equally worried about teams building drive base/bumper assemblies to the maximum allowed dimension, and then regretting this decision when they realize all the cool things they could have achieved with a smaller base that enabled over-the-bumper dropdowns. In past years, iterating in new systems was just a matter of finding the space and weight, this year there are going to be a lot of teams boxed out of improving their robots and adding features like Spectrum has because they assumed bigger=better early in the process.
  #40   Spotlight this post!
Unread 02-02-2017, 16:11
I honestly expect the opposite to happen - teams built chasses that were too small so they could do over-the-bumper stuff, expecting a huge advantage, then realizing it was more trouble than its worth and are now sad about the substantial decrease in ball capacity they traded for that decision.
3847's robot is a good example of leaving a conservative amount of space (just an inch or three) for OTB stuff, but I bet others left way more than they should have.
  #41   Spotlight this post!
Unread 02-02-2017, 17:13
Ty Tremblay's Avatar
Robotics Engineer
FRC #0319 (Big Bad Bob)
Why does a smaller frame necessarily mean a reduction in ball capacity?
  #42   Spotlight this post!
Unread 02-02-2017, 17:37
ngreen ngreen is offline
AKA: Nelson Green
FRC #1108 (Panther Robotics)
ngreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant future
Unless you are expanding your hopper too, which they are.
I really like the design of this robot. I wish we'd have considered a gear pickup on the same side as the fuel intake because I think fuel on the floor will make it difficult to reach gears in some cases.
  #43   Spotlight this post!
Unread 02-02-2017, 23:00
I mean, if you grow your hopper out over the top of your intake, sure. But if you grow your hopper out in that direction, isn't that just going to stick out the same distance as your over-the-bumper intake? Which then isn't sticking out farther than your robot's frame anymore? Isn't that kind of defeating the purpose then?
  #44   Spotlight this post!
Unread 02-02-2017, 23:32
Robotics Engineer
I'm not 100% sure I follow. If you're extending your hopper with your collector, you negate the effects of making your frame smaller while still gaining the advantages of an over-the-bumper collector.
  #45   Spotlight this post!
Unread 02-02-2017, 23:44
cadandcookies's Avatar
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
I'm not sure I follow you now. If you expand your hopper when your intake goes over the bumper, then your hopper is not constrained by your frame perimeter anymore. Thus you're minimizing the effects of lost storage space and still getting your full width over the bumper intake, at the cost of now having to designing the whole expanding hopper thing.
tumblr | twitter
VEXU UMN (2015-??)
Volunteer since 2011
