Go to Post This season, I learned that I will need a whip next year for keeping the electronics and pneumatics groups on schedule. - Yan Wang [more]
Unread 03-02-2017, 21:45
007agentHP 007agentHP is offline
Strategy and Scouting Leader
AKA: Henrique Pereira
FRC #5624 (Tiger Tech)
Team Role: Scout
Rookie Year: 2015
007agentHP is on a distinguished road
pic: Team 5624 Steamworks Robot Teaser
Unread 03-02-2017, 21:47
StrMNX StrMNX is offline
StrMNX is an unknown quantity at this point
Re: pic: Team 5624 Steamworks Robot Teaser
A great looking robot. Although i'm curious, whats the speed/gearing of that drive train?
Unread 03-02-2017, 21:54
Team Role: Scout
Rookie Year: 2015
It is geared for 11 ft/s.
WCP SS gearbox with 44:30 reduction and 14t pinion gears
FRC Team: 5624 TIger Tech
Rookie Year: 2015
Competition Playoffs Record:
Mount Olive 2016 Champs with 1257 and 1676
Bridgewater 2016 Champs with 1676 and 223
N. Brunswick 2015 Quarter-Finalist With 4573 and 4460
Off-season Playoffs Record:
Monty Madness 2015 Finalists with 303 and 1089
Unread 03-02-2017, 21:56
WTFogland WTFogland is offline
FRC #5505
Rookie Year: 2015
WTFogland is an unknown quantity at this point
How are you properly going to use the NavX as it is mounted on the side of your robot?
Unread 03-02-2017, 21:57
ollien ollien is offline
FRC #5202
ollien is just really niceollien is just really niceollien is just really niceollien is just really nice
Why do you have shaft collars on your drive shafts? You're using thunderhex. Just tap it for 1/4-20 and use a washer + bolt to retain the wheel.
Or is this a conscious design decision I'm missing?
FRC #5202
This is completely possible.
http://www.pdocs.kauailabs.com/navx-...ion/omnimount/
Unread 03-02-2017, 22:29
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
If you have the space on the end of the shaft for a shaft collar, there's really no downside to using BOTH a shaft collar and a tapped 1/4-20. Extra security.
Unread 03-02-2017, 22:37
EricH EricH is offline
I'll be that guy:
I assume you have a plan to have your side bumpers properly supported per R31, and it just isn't visible yet? Front/back look to be OK, if the bumpers will fit within the volume.
*Disclaimer: This is CD in Week 4 of Build Season, not your first event, so any rules concerns and/or rulings are based on what is presented here, not the inspection at said first event. There is zero chance that "But CD said it was OK" will get you through inspection.
Unread 03-02-2017, 23:02
Fusion_Clint's Avatar
Fusion_Clint Fusion_Clint is offline
AKA: Clint Brawley
FRC #0364 (Fusion)
Fusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond repute
As long as that 1X1 tube running front to back is 7 inches or lower and that is backing the bumper it could work, I'm guessing the lower edge is at 6 inches. I will recommend bringing some support closer to your wheels either way.
You climber is interesting, it is the first one I've seen in awhile that I think has a chance of actually pressing the touch pad.
Clint Brawley
USAF 1992-2013
Fusion 364, 2014 Season to present
Unread 03-02-2017, 23:49
I'll be that guy:
There are four inch wheels touching the ground, and what appears to be less than a 2 inch gap between those wheels and the member above them spanning the length of the robot. The bumper can likely touch that frame member along its entire length, fully meeting the rule. I don't see the issue here?
Unread 04-02-2017, 00:11
FRC #5505
Rookie Year: 2015
Whoops! Didn't look close enough in the picture to see if there was an omnimount underneath. Figured I would say something just in case though
Unread 04-02-2017, 20:28
Lireal Lireal is offline
AKA: Alex Colello
FRC #2141 (Spartonics)
No, I don't think there is an omnimount. You can programmatically callibrate the Navx to work correctly in any configuration because it senses on all 3 axis of motion.
Unread 05-02-2017, 00:32
If the bumper touches the frame member, it's fine. I didn't see that on the first go-round. (Of course, if for some reason it doesn't, it's an easy enough fix with some strategically placed aluminum.)
Unread 05-02-2017, 00:53
Cash4587's Avatar
Cash4587 Cash4587 is offline
AKA: Cooper Cash
FRC #4587 (Jersey Voltage)
Could be very wrong when saying this, but I really don't think you're going to get 11fps out of this. 3cims on a 50:14 and a 44:30 reduction comes out to be a 5.24:1 overall ratio for a theoretical of 17.76fps or 14.39fps adjusted. That gearing is very fast and you could be prone to brown outs. I would do some testing and adjust your drive speed accordingly.
Unread 05-02-2017, 05:23
FRC #1072 (Harker Robotics)
That seems like a decent speed for a 6-CIM drive on a field as open as this one, but I agree current sensing is wise.
If you really are geared for 11fps, consider going up to at least 15 or 16fps to take advantage of the extra acceleration of 6 CIMs.
Your robot looks very cool! Is that a wooden polycord pulley on the bottom?
