Go to Post I knew you guys were really smokin' at Championships. I just didn't realize how much! - Mark McLeod [more]
Unread 05-02-2017, 21:15
AcesJames's Avatar
AcesJames AcesJames is offline
Mentor, still learning
AKA: James Temple
FRC #2170 (Titanium Tomahawks)(EWCP)
AcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond repute
Send a message via AIM to AcesJames Send a message via MSN to AcesJames
Re: pic: Titanium Tomahawks 2170 Teaser
Originally Posted by D_Price View Post
Looking good! Good luck this year. Only question: Are you worried about being too top heavy when moving throughout the playing the field and suddenly stopping? Just wondering.
Our dimensions (before bumpers) are 22.5 x 24.5 x 35.5, and we have discussed the potential for falling over. Luckily, about 80% of the weight here is within 8" of the ground, and that only looks better when we add bumpers and a battery.
Originally Posted by dodar View Post
Seem some 2009*shudder* inspiration in this robot.
We took a lot of inspiration from 111, 1918, and 2775's 2009 robots here.
Originally Posted by Sperkowsky View Post
I'd work on some weight down low if you can. If you accelerate quickly and then stop suddenly this robot is on its side.
Thanks for letting us know, with such certainty, how our robot will perform. I can only assume you're building the exact same robot and have already driven it?
Originally Posted by Billfred View Post
Best I can tell, 2009 is The Game You Should Be Cribbing Notes Off Of.
Personally, I'm curious about how that ramp is getting raised and lowered. I'm liking the concept though--this is borderline cheesecake-able to help a team operate at a higher level.
Without going into too much detail about our game analysis, we identified 2009 very early on as our primary year of focus in robot design.
That ramp (elevator carriage) is supported on each corner by a 3D printed bracket bolted to a linear bearing. The bearings are each riding on a stainless steel rod, one in each corner. The current plan is to have a run of #25 chain on either short side of the robot (two total) and bolt the chain to the carriage. Idler sprockets at the top of the robot will be connected by a shaft and we'll tuck a gearbox in the drivebase to power it on one side.
FRC 176 - Aces High - 09-12 - Student
FRC 229 - Division By Zero - 13-14 - "Mentor"
FRC 2170 - Titanium Tomahawks - 17-Now - Mentor
