Go to Post Right now that dream is sealed behind a few milimeters of plastic for most teams. - AllenGregoryIV [more]
Unread 05-02-2017, 21:41
AcesJames's Avatar
AcesJames AcesJames is offline
Mentor, still learning
AKA: James Temple
FRC #2170 (Titanium Tomahawks)(EWCP)
AcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond repute
Send a message via AIM to AcesJames Send a message via MSN to AcesJames
Re: pic: Titanium Tomahawks 2170 Teaser
Originally Posted by 1493kd View Post
Does your "elevator ramp" drop down to "ground level"? How are you lifting ground fuel up to the "ramp"
There will be a cut out in the front of the ramp. Another roller will go between the white intake roller and the first black dump roller. The intake roller and this new roller will be wrapped together with polybelt. Behind these rollers we'll have a vertical wall of material that will cause the balls to roll up and then out and down onto the ramp - we're calling this the "Waterfall".
The cut-out piece of ramp will be re-attached with a hinge to act as a "trap-door" that folds out of the way when the elevator is in the floor position, and folds back down when the elevator lifts the ramp to score in the low goal (between the two black rollers) or dump into other robots (above the top black roller).
FRC 176 - Aces High - 09-12 - Student
FRC 229 - Division By Zero - 13-14 - "Mentor"
FRC 2170 - Titanium Tomahawks - 17-Now - Mentor
