Go to Post Disclaimer: I am not an electrical engineer nor an electrician. I occasionally play one on CD. And when inspecting robots, sort of... - jvriezen [more]
  #32   Spotlight this post!
Unread 06-02-2017, 17:45
pmattin5459 pmattin5459 is offline
AKA: Patrick Mattin
FRC #5459 (Ipswich TIGERS)
Rookie Year: 2015
pmattin5459 will become famous soon enoughpmattin5459 will become famous soon enough
Re: pic: 3322 First Design Iteration / Practise Bot
Originally Posted by messer5740 View Post
Ok our team designed a passive gear deliverer system too, we are testing in a few days at a practice field...hopefully you are right about the less hassle! Do you think having a drivetrain that allows linear strafing would also save time when depositing?
Depends. Have you done linear strafing in the past? Are your drivers familiar with it? It isn't going to help much if your drivers aren't used to it, especially considering that opposing robots can push you sideways much more easily.
Edit: Also, your drivetrain should probably have been decided upon and built by this point. If it has not, take your kitbot and build a tank drive. Week 4 is not the time to make these sorts of decisions. Source: my team did mecanum last year, and had no idea what we were doing. If you do decide to go this path, send me a PM, because there's a few things you'll need to know.
