Go to Post No amount of sleep beforehand will make up or prepare you for the lack of sleep you will receive during build season. - Dan Petrovic [more]
Unread 07-02-2017, 09:17
eedoga's Avatar
eedoga eedoga is offline
FRC #2980
eedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud of
Re: pic: Team 2980 CADD of Current Design
Originally Posted by tpvagnini View Post
I'd suggest you put more resources (and robot volume) into your main mechanisms so your robot will be stronger with fuel or gears. From experience, being an "all around bot" isn't the best. It's much better to have a couple of very effective mechanisms on your robot rather than many that may work only okay.
So something a lot of people don't know about our team is that the team does not decide on the final build requirements. The community does. We come up with a few different designs, present them to our local community, and the community decides what we actually end up building. It is not our robot, but instead the robot is commissioned by our local community. We then compete on their behalf.
We (including our local community) considered the idea that we were trying to do too much by being an "all around" robot. and perhaps that is true, but then we began to question what we should give up and what would be gained by doing so...
Gear placing? We are pretty well convinced that no single robot will be capable of placing 12 gears 1 at a time. The cycle times would have to be incredibly short, and the hang up here would be the last 6 gears...
Shooting? Again we thought it through, and yes, if you can carry 40 balls and have a 100% accuracy rate, then sure you can do it by yourself. If you can shoot during autonomous then you might have a cushion for a lower accuracy rate, but even so...
Climbing? That was a non-starter with the community. They want to see the robot hanging from the ceiling.
Now here is the odd point. Our team has usually relied on defense. We have always figured if nothing else works at least you can keep the other team from scoring. By having this option we have sometimes not worked as hard as we could in order to find ways to make things work. We have sometimes relied on lazy solutions and not thoroughly tested our mechanisms...
The community decided very specifically to limit that option. They are in fact pushing us to grow. I believe someone said, "if we don't push them then they will never grow."
Now as to the floor loader, it is in direct response to a team suggesting on chief delphi that in order to limit scoring ability of shooting robots you simply drive around dumping all of the hoppers on the ground...
So, while we can focus on gears if we end up in a situation where gears are being done by our alliance partners and the hoppers are constantly being dumped we will still be able to contribute something through shooting. We understand this may not be a likely situation, but it was in the design requirements so...
A few days ago we made a mock up hopper out of cardboard. It can hold about 40 balls with a perfect pour...SO, maybe 30 balls? We'll have to see how many actually end up making it from the hopper to the boiler. The other side of it is that because we are shooting from a known location we believe that we can expect a higher level of accuracy, even with relatively high cycle times. In the end we may not be able to contribute an entire ranking point on our own, but hopefully we can contribute our share.
We understand that this may not be the most successful design. We may end up being out classed by other robots in every way. We may go to our first district event and place so low that there is no possible hope of moving on. We understand all of these things. We also understand that those things in the end don't matter as much as satisfying the community that gives so graciously so that our team can continue to thrive. This is a growth year for us, and the community understands that we may not do well this season because of our choices, but they don't care so long as we actually grow.
Hope this all makes sense.
Edoga
