Go to Post 254 isn't just good at building their robot. They're also good at taking pictures of it. - Chickenonastick [more]
Unread 07-02-2017, 10:06
rich2202 rich2202 is online now
FRC #2202 (BEAST Robotics)
rich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond repute
Re: pic: Power Over Ethernet for 2017
Originally Posted by RufflesRidge View Post
I'm assuming you mean run a separate cable for the barrel jack and not trying to plug in both the Ethernet pigtail and the barrel jack from one of the Adafruit cables into the radio right?
Just so it's clear to others, that would not result in powering the "PoE" port on the radio as the Ethernet pigtails on those cables do not have power on the pins, the Ethernet cable you connect to the female Ethernet jack on the cable does.
I think the idea is to take the power for the Radio and split it with something like this:
https://www.amazon.com/SIM-NAT-Split...dp/B01GPRLQCC/
You then plug one of the male plugs directly into the radio, and the second male plug into:
https://www.amazon.com/iCreatin-Pass.../dp/B00NRHNPUA
The male Ethernet connector goes into the RoboRio, and you use a CAT5 or CAT6 cable to connect the female end into the radio.
Thus, the radio receives power directly, and through the Ethernet cable.
