Go to Post The only basis on which a team should be awarded the chairmans award is the content of the submission, not the way in which it is presented. - KenWittlief [more]
Unread 07-02-2017, 11:24
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Re: pic: Power Over Ethernet for 2017
Originally Posted by RufflesRidge View Post
I'm assuming you mean run a separate cable for the barrel jack and not trying to plug in both the Ethernet pigtail and the barrel jack from one of the Adafruit cables into the radio right?
Just so it's clear to others, that would not result in powering the "PoE" port on the radio as the Ethernet pigtails on those cables do not have power on the pins, the Ethernet cable you connect to the female Ethernet jack on the cable does.
Yes I mean running a separate power cable for the barrel jack, and they are both powered off the VRM. You will know you did it correctly when you can unplug the barrel jack or the Ethernet cable and the radio still maintains power as long as one of them is still connected.
