Go to Post I hope that all of our new members are as helpful as the one above. We will be in for an amazing season if that is the case. - Greg Needel [more]
Unread 07-02-2017, 17:15
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
FRC #2168 (The Aluminum Falcons)
otherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to behold
Re: pic: Power Over Ethernet for 2017
Originally Posted by jnicho15 View Post
How do you comply with wire gauge restrictions when doing this? Most ethernet cables are 23-26 ga. (usually 24) but 22 ga. is required in the manual for 12v 2a.
https://en.wikipedia.org/wiki/American_wire_gauge
22awg =0.326 mm^2
The passive power injectors use pairs of conductors for sending power and ground (a total of four conductors used).
24awg = 0.205 mm^2
So you effectively you have 0.410 mm^2 cross sectional area of copper which exceeds the 22awg requirement.
At least that's how I was planning on explaining it away if the question came up.
http://team2168.org
