Go to Post ...we are all winners when people come out of this program and strive to make the world a better place. - Patrick Wang [more]
Unread 07-02-2017, 17:17
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
FRC #2168 (The Aluminum Falcons)
otherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to behold
Re: pic: Power Over Ethernet for 2017
Originally Posted by Mark McLeod View Post
Ah, too many assumptions.
You can't actually use that injector in the configuration you were thinking of.
Power is only injected into the female end, not the male end.
This is the picture I posted of my setup when I talked about it: https://www.chiefdelphi.com/forums/a...7&d=1484316250
If you read what I wrote, I did assume the female end was where the power was being injected from. I assumed it was being used literally the way it's depicted in the product posting.
edit: specifically:
The other dongle plugged into the RIO, then a power extension plugged into the female barrel to get to a VRM.
http://team2168.org
