Go to Post Someday, when I grow up, I want to join the GDC so I can make people go crazy, and then release hints that get people even crazier. - unionylibertad [more]
Unread 07-02-2017, 15:02
itsjustmrb itsjustmrb is offline
FRC #4063 (TRikzR4kiDz)
itsjustmrb is a splendid one to beholditsjustmrb is a splendid one to beholditsjustmrb is a splendid one to beholditsjustmrb is a splendid one to beholditsjustmrb is a splendid one to beholditsjustmrb is a splendid one to beholditsjustmrb is a splendid one to behold
pic: 2" Mecanum
Unread 07-02-2017, 15:13
Max Boord Max Boord is offline
FRC #0179 (The Children of The Swamp)
Team Role: Tactician
Max Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant future
Re: pic: 2" Mecanum
Have you guys tested these? I have always wanted to try 3d printing mecanum intake wheels but have not found a design/ filiment combination that I thought would hold up to robot to robot contact.
1523 (2011-2014)
1065 (2014-2016)
3932 & 4592 (2016)
1592 (2016-2017)
Unread 07-02-2017, 15:15
FRC #1072 (Harker Robotics)
Re: pic: 2" Mecanum
Very cool! I would love to see some durability tests on these just because the material around the rollers looks a bit thin, but for intake purposes they look very capable.
Unread 07-02-2017, 15:38
Clayton Summerall's Avatar
Clayton Summerall Clayton Summerall is offline
FRC #4587 (Jersey Voltage)
Clayton Summerall is on a distinguished road
Re: pic: 2" Mecanum
Where did you buy the rollers? Would you mind sharing the CAD file?
Unread 07-02-2017, 16:14
Big-b's Avatar
Big-b Big-b is offline
FRC #0900 (♞Zebrarcorns♞)
Rookie Year: 2016
Big-b has a spectacular aura aboutBig-b has a spectacular aura about
Re: pic: 2" Mecanum
It looks like those are printed as well.
Unread 07-02-2017, 16:20
Cothron Theiss's Avatar
Registered Muser
Cothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond repute
Re: pic: 2" Mecanum
They actually look injection molded to me, but I might be wrong.
All in all, the look great! I will say, I think you could add a little bit of a fillet to all those interior angles and see some substantial gains in durability. Also, will these wheels ever be outside of your bumpers?
Unread 07-02-2017, 16:53
s-neff's Avatar
s-neff s-neff is offline
AKA: Sam
FRC #0841 (Biomechs)
s-neff has much to be proud ofs-neff has much to be proud ofs-neff has much to be proud ofs-neff has much to be proud ofs-neff has much to be proud ofs-neff has much to be proud ofs-neff has much to be proud ofs-neff has much to be proud ofs-neff has much to be proud of
Re: pic: 2" Mecanum
Awesome! What was the manufacturing process for the rollers? Mind sharing the material choice? It's awesome that it looks like you don't have to run a brass sheath on the inner surface.
Are the lock nuts really <1/4" across? I haven't been able to source anything less than 1/4" wide off McMaster, which has made packaging the fasteners difficult. Or do you just accept that the nuts break the plane of the wheel, since it's only an intake for a round game piece?
Fun:
Mentor - Team 841 (2015 - ? )
Mentor - Team 4 (2013 - 2014)
Student - Team 192 (2009 - 2010)
Work:
SunPower Systems, Product Engineering - Utility Power Plants (2015 - ? )
BSci, Mechanical Engineering, UCLA (2010-2015)
Unread 07-02-2017, 18:31
Re: pic: 2" Mecanum
Those look like rubber rollers...
Unread 07-02-2017, 21:51
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: pic: 2" Mecanum
If you're printing your own vectored intake wheels anyways, you should totally experiment with the roller angle to see what shoves the balls sideways the fastest. If I'm understanding Ether's mecanum kinematics paper and reasoning correctly (questionable propositions, both) then making the rollers more perpendicular should move the balls sideways faster. Maybe. Completely perpendicular or parallel both obviously fail, so maybe 45 is the fastest, but it just feels like something else should be.
Unread 07-02-2017, 22:08
Registered Muser
Re: pic: 2" Mecanum
Ooh, I like this idea. Do you know of anyone that's made custom mecanums for drive wheels that are anything other than 45°? You could do some really interesting drives that either have more or less power when strafing than usual. Course, they're still a waste of time. But that's beside the point.
Unread 09-02-2017, 14:52
Re: pic: 2" Mecanum
This is the first batch I have printed with the hex bore and they have held up pretty well. The intake is inside the robot this year, so I am an not too concerned.
2016 Hub City Regional Winner #3 Seed (3310 & 4301)
2016 Bayou Regional Winner #1 Seed (233 & 4087)
2015 Dallas & Alamo Creativity Award
2015-2016 Hub City Regional Gracious Professionalism
2014 Hub City Regional Engineering Inspiration
2012-2016 Alamo Regional Gracious Professionalism
2016 Bayou Regional Gracious Professionalism
2014 Dallas Regional Gracious Professionalism
2013 Alamo Regional Winners (2468 & 2789)
Unread 09-02-2017, 14:54
Re: pic: 2" Mecanum
The axles are M3 40mm stainless steel with nylock nuts.
