Go to Post If no hint or advanced BOM don't come out, will it make you not participate in FIRST this year?? - Elgin Clock [more]
Unread 08-02-2017, 10:07
Tsukunea's Avatar
Tsukunea Tsukunea is offline
Lead Designer, Drive Coach
AKA: Boone Shangle
FRC #6065 (Titanium Dragons)
Rookie Year: 2016
Tsukunea has much to be proud ofTsukunea has much to be proud ofTsukunea has much to be proud ofTsukunea has much to be proud ofTsukunea has much to be proud ofTsukunea has much to be proud ofTsukunea has much to be proud ofTsukunea has much to be proud ofTsukunea has much to be proud of
pic: Team 6065 Chassis
Unread 08-02-2017, 10:09
Re: pic: Team 6065 Chassis
This is a really nice chassis. Great use of COTS parts to build a simple robust frame. My favorite detail is the use of the angle brackets to mount the superstructure to both sides of the drive rail - I wish I had thought of something robust like that for my own team's frame!
Will you have any more cross-support for this chassis than what is shown? Perhaps in your superstructure? Right now, just the one member in the back for cross support might result in a less rigid frame than you'd prefer. Easy ways to stiffen the frame up include tying the two gearboxes together with standoffs, or running a 1x1 across the top of the frame somewhere (maybe directly behind the gearboxes?)
In any case, this is a great frame.
Unread 08-02-2017, 16:05
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Also, make sure that you are supporting your bumpers along the sides every 8 inches. Right now that span is wide open.
Unread 08-02-2017, 16:14
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Nice, with a few issues.
In addition to those raised by Chris and Tom, using the AM Battery mount kit like this may not properly secure the battery. It is designed to fit inside the AM14U2/3 end sheet, which is basically a piece of 3" channel. Even after you put in the bungee, the battery would be free to rotate around a horizontal axis running left-to-right. That is, the bottom could come forward, and the top go back. Once it rotates a little bit, it's free to slide right out either way (though most likely forward onto the belly pan). Another bar like the one at the top placed at the bottom would resolve this.
Unread 08-02-2017, 16:15
JR0405's Avatar
JR0405 JR0405 is offline
Electrical & Pneumatics/Mechanical
AKA: Jack Ross
FRC #5822 (Wolfbyte)
JR0405 is a name known to allJR0405 is a name known to allJR0405 is a name known to allJR0405 is a name known to allJR0405 is a name known to allJR0405 is a name known to all
In addition to those raised by Chris and Tom, using the AM Battery mount kit like this may not properly secure the battery. It is designed to fit inside the AM14U2/3 end sheet, which is basically a piece of 3" channel. Even after you put in the bungee, the battery would be free to rotate around a horizontal axis running left-to-right. That is, the bottom could come forward, and the top go back. Once it rotates a little bit, it's free to slide right out either way.
Could this be solved by covering each side?
#StaySavage
Unread 08-02-2017, 16:47
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Yes - you got this before I added the last sentence. Another bar like the one currently at the top placed at the bottom would do it. Yet another at the back top or enclosing both sides would be great for keeping the battery in, but might make it all but impossible to get the battery in or out (short of rotating the whole robot).
