Go to Post This is a very cool robot. It doesn't look like a launcher... it looks like a lifter driving backwards. Then whammo! The ball is flying through the air. - dtengineering [more]
  #32   Spotlight this post!
Unread 26-06-2003, 14:16
Originally posted by Matt Reiland
There used to be two on the Design from 2002, there is only one shown on this newer smaller version for 2003
Does it work okay with just one? Well, I suppose it does from what I read about the transmission's success. But wouldn't the gear wobble some on the shaft with only one bearing in there?
EDIT: One more question, what would be the pros and cons of machining the dog mates right into the hub of the gear as opposed to using a hubless gear and machining separate dog mates? I'm just thinking about less complexity.
pic: IRI 2003 Belly Check CD47-Bot Extra Discussion 17 24-07-2003 16:49
pic: 2003 IRI - DJ crowning CD47-Bot Extra Discussion 33 23-07-2003 22:48
pic: TechnoKat High School Wall CD47-Bot Extra Discussion 22 22-05-2003 16:47
pic: 2003 TechnoKat Ball Drive : Patent Pending CD47-Bot Robot Showcase 78 30-03-2003 16:27
Image Discuss: TechnoKat Robot 2003 - 2 CD47-Bot Robot Showcase 6 27-02-2003 14:44
