Go to Post If we can figure out how to make a robot in six weeks, a little thing like personality conflict should be easy to overcome. - Al Skierkiewicz [more]
  #33   Spotlight this post!
Unread 26-06-2003, 14:36
Matt Reiland's Avatar
Matt Reiland Matt Reiland is offline
'The' drive behind the drive
None #0226 (TEC CReW Hammerheads)
Matt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond repute
Originally posted by sanddrag
Does it work okay with just one? Well, I suppose it does from what I read about the transmission's success. But wouldn't the gear wobble some on the shaft with only one bearing in there?
EDIT: One more question, what would be the pros and cons of machining the dog mates right into the hub of the gear as opposed to using a hubless gear and machining separate dog mates? I'm just thinking about less complexity.
The flanged bearings used are pretty beefy, they are about 1/4" thick so as long as your machining tolerances are good, there should be no wobble. You also want your tolerance very close on the bore of the output gears so that they dont' fall off the flanged bearings when they aren't engaged to the dog.
As for machining the dog mates into the gear, it is the way to go, we used separate dog mates and ended up welding them onto the hubless gears. Keep in mind that by machining them into the gears, the gearbox gets much narrower than if the dog mates protruded outwards. The dog mates themselves seemed more complex to machine than actually milling in simple pockets on a rotary table of a milling machine also.
Robonaut Next Generation Control System Development
2003 GLR Champions (302,67,226)
2003 Buckeye Semi-Finalists(902,494,226)
2002 Nationals QuarterFinalists
2001 West MI QuarterFinalists
2000 GLR Semi-Finalists
pic: IRI 2003 Belly Check CD47-Bot Extra Discussion 17 24-07-2003 16:49
pic: 2003 IRI - DJ crowning CD47-Bot Extra Discussion 33 23-07-2003 22:48
pic: TechnoKat High School Wall CD47-Bot Extra Discussion 22 22-05-2003 16:47
pic: 2003 TechnoKat Ball Drive : Patent Pending CD47-Bot Robot Showcase 78 30-03-2003 16:27
Image Discuss: TechnoKat Robot 2003 - 2 CD47-Bot Robot Showcase 6 27-02-2003 14:44
