Go to Post "Your really pretty and I like your bot" - prettycolors91 [more]
Unread 13-07-2003, 01:31
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
Andy thanks for the words of encouragement, i was thinking about changing some of the gearing ratios around and just tinker a little to see what i can do with the output. i am wondering if i make it so the output has higher torque and less rpm's, what it may do on the voltage input, if it may draw more or if it could cause a stall on the motor or what may happen...
~Mike
"Make Failures and LEARN By Them, DO NOT Let Your Own Failures, Get You Discouraged..."
-Michael Dessingue
White Paper Discuss: Dual Motor Gearbox - 2003 CD47-Bot Extra Discussion 6 08-04-2004 19:46
Some code in C that we may need if we are in trouble Andrew Rudolph Chit-Chat 16 07-10-2003 21:34
Shift on the fly LEGO gearbox rlowerr_1 Robot Showcase 17 14-07-2003 23:33
