Go to Post Yes, a big part of FIRST is learning from others. But a just as important part of FIRST is learning from discovery. - [more]
Unread 14-07-2003, 23:42
Gadget470's Avatar
Gadget470 Gadget470 is offline
A Fire Outside
AKA: Brandon Joerges
no team (Alpha Omega)
Gadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the rough
Send a message via ICQ to Gadget470 Send a message via AIM to Gadget470
Originally posted by rlowerr_1
nice, but dont you have any problems with the spacing? By the looks of it you could be in two gears at the same time... which would not be good.
Also where are the motors? Get that thing running!
He should be fine with spacing, put 3 fingers on the screen, one over each of the shifting gears. Slide your hand a bit and see where each one lines up when the other meshes. You'll see each one should cleanly be going into the next (less the forced mesh). Now yes, I don't think Tytus busted out a micrometer to make sure that it all works correctly, but it's within a millimeter of working. (Can't prove yes or no because I can't touch it)
pic: 2 speed shifty on the fly Lego Bot CD47-Bot Robot Showcase 9 31-01-2005 04:21
pic: Lego Swerve Drive CD47-Bot Robot Showcase 14 26-06-2003 16:19
