Go to Post I come to Chief Delphi to get away from the mundane, everyday news. It's part of what makes the forum appealing to me. If I want to read world news, I'll go to digg. - Ryan Dognaux [more]
  #47   Spotlight this post!
Unread 23-07-2003, 14:41
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
Martin has and 11 tooth 20dp gear and a 10 tooth 20dp spline shaft. We used them both this year.
This was one of our "lessons learned" from 2003: leave yourself enough center distance to vary a wide range of gear ratios after the output shaft of the shifting gearbox.
From the output shaft of our gearbox, we had a coupler, a gear reduction, and then our drive wheel. This gear reduction started out as 2.5:1, but it ended up being 4:1, using a 41 tooth gear (custom) and a 10 tooth gear. I wish we knew we needed a 4:1 when we set the center distances of the gears... they would've been farther apart. This mistake was the cause of many mechanical breakdowns (3 in Pittsburgh and 1 in Chicago).
Andy B.
pic: IRI 2003 Belly Check CD47-Bot Extra Discussion 17 24-07-2003 16:49
pic: 2003 IRI - DJ crowning CD47-Bot Extra Discussion 33 23-07-2003 22:48
pic: TechnoKat High School Wall CD47-Bot Extra Discussion 22 22-05-2003 16:47
pic: 2003 TechnoKat Ball Drive : Patent Pending CD47-Bot Robot Showcase 78 30-03-2003 16:27
Image Discuss: TechnoKat Robot 2003 - 2 CD47-Bot Robot Showcase 6 27-02-2003 14:44
