Go to Post As Shakespeare once said in Julius Caeser, "Cowards die many times before their deaths; the valiant never taste of death but once." - artdutra04 [more]
Unread 05-09-2003, 22:59
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
pic: Diff lego experment
Unread 05-09-2003, 23:02
Trashed20's Avatar
Trashed20 Trashed20 is offline
Boom, Shawalala Boom!
#0862 (PCEP Lighting)
Trashed20 will become famous soon enough
Send a message via AIM to Trashed20
neat. i'm still amazed at what people can do with legos these days. The one thing i would say is try to get it as small as possible so it would be feasable in an actual robot. Cool nonetheless.
Where has all the fun gone?
Unread 06-09-2003, 01:11
Kevin A Kevin A is offline
In Hibernation
#0481 (DART)
Kevin A will become famous soon enough
Send a message via AIM to Kevin A
So howd it work?
Unread 06-09-2003, 11:37
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Originally posted by Tytus Gerrish (in the caption for this picture)
It SO! works
With a standard, and a micro lego motor, tested using my fingers as a load
with an unmovable load the motors don't Overpower each other they just stall and don't move. NO moving bakwards
i admit these are just legos and a true test is required
Tytus, do you have the rpm and power on hand of each of those motors (i.e., how similar are they)? I'm curious as to whether the differential was actually working as anything but a fancy shaft (if the speeds were identical, the housing of the differential would rotate, but the bevels inside wouldn't turn--hence, a shaft).
If the differential were matching speeds, then you might be at risk of stalling one or the other (as Bill Beatty suggested in the other thread), depending on the conditions of the test (e.g. relative power and relative speed of the motors--speed would have to be different, and power similar). You should also note that these are small brushless motors. Stalling these is no problem, but on the FIRST robots, the motors are not nearly so pleasant when they are stalled.
In short, while it may work now, it probably isn't an accurate enough simulation of a Bosch 3360 and a CIM FR801 (like you admitted...).
-Tristan Lall
Unread 06-09-2003, 12:30
The little red one has a little more torque than the big grey one but the big grey one is a lot faster.
Unread 06-09-2003, 15:38
patrickrd's Avatar
patrickrd patrickrd is offline
AKA: Patrick Dingle
patrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to behold
Send a message via AIM to patrickrd
Question What is a differential?
I have been occasionally reading the posts over the past couple months on differentials, and then saw this one made out of legos. Can anyone provide a link or good technical explanation of what one is and how it works? These pictures do not do it for me.
Thanks, and nice lego building skills
- Patrick
Systems Engineer - Kiva Systems, Woburn MA
Alumni, Former Mechanical Team Leader - Cornell University Robocup - 1999, 2000, 2002, 2003 World Champions
Founder - Team 639 - Ithaca High School / Cornell University
Alumni - Team 190 - Mass Academy / WPI
Unread 06-09-2003, 16:16
Anthony Towne Anthony Towne is offline
#0176 (Aces High)
Anthony Towne is an unknown quantity at this point
Send a message via AIM to Anthony Towne Send a message via Yahoo to Anthony Towne
http://auto.howstuffworks.com/differential.htm Howstuffworks.com has pretty good explanations and pictures that explain how a differential works, among a number of other things. Hope this helps.
Team 176 Aces High
Mechanical Design Engineer, Hamilton Sundstrand
Unread 06-09-2003, 16:46
rlowerr_1's Avatar
rlowerr_1 rlowerr_1 is offline
#0930 (M³)
rlowerr_1 is an unknown quantity at this point
Send a message via AIM to rlowerr_1
For those interested this link has comparisons of all the current lego motors. The red motor (dubbed the minimotor by LEGO fans) offers very little speed and torque.
Ryan Lowerr - Ryan@lowerr.com
Check out my LEGO creations here!
Unread 06-09-2003, 17:32
P.J. Baker's Avatar
P.J. Baker P.J. Baker is offline
needs a clever user title
FRC #0177 (Bobcat Robotics)
P.J. Baker is a glorious beacon of lightP.J. Baker is a glorious beacon of lightP.J. Baker is a glorious beacon of lightP.J. Baker is a glorious beacon of lightP.J. Baker is a glorious beacon of light
Not sure...
Based on the characteristics for those LEGO motors, I'm not sure that your experiment should have worked out the way you think it did.
The larger motor has about 4 times the stall torque of the smaller motor. If this is the case, then the larger motor should have been able to back-drive the smaller one when you stalled the output shaft.
In a standard open differential, the same torque is always put out to each side, regardless of the output speed. This is why a car with an open differential rear end will get stuck even if only one of it's driven wheels is in a mud puddle or on a patch of ice. The proposed reverse differential drive should ensure that both inputs sides are supplying the same amount of torque - regardless of speed.
But... If the two motors can not supply the same stall torque and the output shaft is stalled, the torquier motor must back-drive the other motor. This will increase the back EMF of the stronger motor, reducing its torque output. It will also (I think) create negative back EMF on the weaker motor, INCREASING its output torque.
With one motor having 4X the stall torque of the other in your LEGO design, I think that you should have seen back driving of the smaller motor. There are two things that could have kept this from occurring (assuming the transmission was correctly assembled). First is that the battery you used could not supply enough current to the motors when you stalled them out. Second is that there appears to be some thermal protection for the gray motor, a thermistor that would cut the power when the current gets too high.
Since it looks like the red motor doesn't have the thermal protection, I would repeat the experiment with two red motors, but gear one of them down 2:1 before running it into the diff. Also make sure that you have new batteries, one for each motor.
In closing, I'll repeat what I said in one of the other threads about this transmission. If you gear the motors so that their stall torques (not their free speeds) are matched prior to entering the differential, this drive should work. I think that this set up is more electrically efficient that a matched speed (locked differential) drive - but I'm not sure that it makes sense in terms of bang for your buck. That's not necessarily what FIRST is all about though, so build it if you can.
Sorry this was so long.
Good Luck!,
P.J.
Unread 06-09-2003, 17:54
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
Adam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to behold
Send a message via AIM to Adam Y.
Everything I have read so far seems correct except for the part about the motors. Negative back EMF is created when the motors are spinning at full speed and barely showing little or no torque. The one thing I think will happen is that the little motor will actually become a generator and may actually blow the electronics controlling it. I remeber someone mentioning this.
If either a public officer or any one else saw a person attempting to cross a bridge which had been ascertained to be unsafe, and there were no time to warn him of his danger, they might seize him and turn him back without any real infringement of his liberty; for liberty consists in doing what one desires, and he does not desire to fall into the river. -Mill
Unread 06-09-2003, 19:31
I thought the red minimotor was more torquey by my own "measurements" by playing around with them. I suppose I was wrong.
I wonder if a Torsen Differential would work work with this setup?
Unread 07-09-2003, 20:59
patrickrd's Avatar
AKA: Patrick Dingle
Thanks! The article explained it perfectly. Now I have to try and do my microeconomics homework while my brain wants to think about differentials
- Patrick
Unread 08-09-2003, 13:44
Jnadke Jnadke is offline
Go Badgers!
#0093
Jnadke is on a distinguished road
Send a message via ICQ to Jnadke Send a message via AIM to Jnadke Send a message via Yahoo to Jnadke
For all readers, it must be noted that lego concepts can only prove feasibility and not any physical concepts. In the case of this test, these motors are only generating mere milliNewtons of torque. Simple gear friction would be enough from causing one motor to be back-driven.
It must be noted that motors would only fight if their torque characteristics were too dissimilar. Even then, they would only fight if one motor was operating at or near stall.
The best moments of our lives fall in two categories: those that did happen and those that did not.
pic: Coaxial Lego doubble-wishbone crab CD47-Bot Robot Showcase 7 10-12-2003 12:10
pic: poor mans Lego Coaxial crab CD47-Bot Robot Showcase 8 23-10-2003 22:00
pic: LEGO Vernier Gearbox CD47-Bot Extra Discussion 9 10-10-2003 09:43
pic: lego Planitary... Kinda CD47-Bot Extra Discussion 5 14-07-2003 23:55
pic: Lego Swerve Drive CD47-Bot Robot Showcase 14 26-06-2003 16:19
