Go to Post Wow, I can't wait for Karthik and I to battle it out on "International Mid-life Crisis Idol". - Travis Hoffman [more]
Unread 09-09-2003, 08:58
Andy Brockway Andy Brockway is offline
Engineer
FRC #0716 (Who'sCTEKS)
Andy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond repute
I am planning a white paper detailing the shifter mechanism within the next two months. I will include gear ratios and main plates in the write up.
In the meantime, The approximate weight without motors is 5 lbs. This is only an estimate as I forgot to do a weight check.
The output speed at the shaft is 162/684 rpm for low/high. We reused the gear on the CIM and the sprockets from the output so this dictated some of the ratio decisions.
This box is 2-5/16" wide by 2-3/4" tall. I am guessing it to be about 7" long, I left the file at home. The plates are 1/4", the ouput bearings are not flanged so the button heads keep them in.
I have been running flat out the last few weeks at work so I am a little behind on everything. I will answer questions as fast as I can.
White Paper Discuss: Dual Motor Gearbox - 2003 CD47-Bot Extra Discussion 6 08-04-2004 19:46
White Paper Discuss: 2 speed, Shift-on-the-fly TechnoKat Gearbox CD47-Bot Extra Discussion 35 23-01-2004 20:16
pic: LEGO Vernier Gearbox CD47-Bot Extra Discussion 9 10-10-2003 09:43
Multi Speed Dual Motor Gearbox tenfour General Forum 14 08-09-2003 13:09
