#16
No news on the OI yet, is there...
I'm thinking it'll be the same, because of the lack of an OI for the vetern teams to use with the EduBot RC. One thing that I'm not sure about though, what about the dashboard port. Will that change this year, or will it stay the same? I'm hoping we have control over it this year, but I haven't seen any information on that yet. |
#17
there is really no reason to change the OI. (well i guess i can think of a few)...
Hrmmm.... Whats up with the "PWM in"? |
#18
The Digital In/Out's got me thinking...
I wonder if we'll be allowed to interface the Digital In/Out from the eduRc straight to the Digital in/out on the Full RC for competition? Then the eduRC could handle some low-level processing and data storage for auto mode, and the full rc would handle high-level processing, and main operation data... Hmm... I wonder if this will be allowed of not? I'm tinkering with putting together some C headers w/ structures now, so I can get going as soon as we get our new RC The fact that Vet's aren't getting new OI's pre-season is leading me to believe that there will be few changes to the new OI, if any. I assume the Dashboard port may change, and a new Dashboard program will be released. Not much really needs to be done to the OI... Maybe a longer adapter cord? Who Knows... ![]() |
#19
Im quite impressed. I need to learn C for this, but it is worth the effort.
Also, since we (apparantly) can code in assembly, and I am quite fluent in x86 assembly, would it better for me to learn C or the PIC assembly? Finally, I can't wait to see some default code. |
#20
Also, if there's an imposed limit on price for external electronics, again, it might not be legal to use an EduRC in conjunction with the FRC RC, depending on its price. |
#21
you would definately want to learn C before you learn assembler.
assembly code is tedious and error prone. |
#22
Also, concerning the posted specs, shouldn't the PIC18F8520 be running at 40MHz, instead of 50MHz, as IFI says? The processor is listed as having a maximum Fosc of 40MHz, on Microchip's page. <edit> Deleted something stupid. Thanks to Matt Leese for pointing it out. ![]() </edit> Last edited by FotoPlasma : 02-10-2003 at 02:40. |
#24
Now, obviously, that won't be an issue here (I'd be highly surprised if any team managed to even come close to maxing out the serial port) but I thought it was important to point out. Matt |
#25
I believe the ~40 Hz number you produced came from the fact that the robot controller received input data approximately 40 times a second. Given that it blocked before reading data, it basically meant you went through your loop 40 times per second. Matt |
#26
I've been asking around and no one seems to know ![]() |
#27
This is mostly an educated guess but I'm assuming TTL Serial port means that the line level outputs of the serial port are at TTL level. TTL level defines zero as from 0 to 0.8 V and a one as from 2 to 5 V. Now, normal RS232 Serial Ports have an operating range from -15V to 15V for their output. The TTL Serial Port is a serial port that is specifically designed to interface with either TTL or TTL-compatible circuits. This means that it's much more effective for controlling a custom circuit than a regular RS232 Serial Port.
Matt |
#28
I agree with Matt. It would be an easy way to connect to a second PIC chip (if you want to use one for something else) and it would act just like an RS-232 link, expect you dont need the tranceivers to convert the voltage levels, since your second PIC chip will only be a few inches away from the robot controller.
This new robot controller is really going to open up a lot of possiblilites for teams with EE's and SW engineers to do some impressive stuff with the machines. |
#29
Finally, power real power. Now the programmers can take over the world.
Oh, sorry. I think I'm getting a little carried away ![]() |
#30
Now, you're gonna have to look for new excuses. Have fun, bit-twiddlers! ![]() Andy B. |
| serious problem found - robot controller resets when jarred! | KenWittlief | Electrical | 23 | 19-03-2003 13:30 |
| How do you connect the speed controller fans? | Iain | Electrical | 7 | 31-01-2003 07:05 |
| visibility of robot controller? | davidzhang | Rules/Strategy | 5 | 26-01-2003 01:11 |
| Q&A Discuss: Are specs available on the new motors/mounts? | CD47-Bot | Extra Discussion | 3 | 15-01-2003 19:39 |
| Motor specs | kmcclary | Off-Season Events | 4 | 26-10-2001 22:41 |
