Go to Post Look around. What else could cause folks to go sleepless for six straight weeks? That's life-changing, isn't it? :D - Billfred [more]
Unread 08-10-2003, 22:40
Kevin A Kevin A is offline
In Hibernation
#0481 (DART)
Kevin A will become famous soon enough
Send a message via AIM to Kevin A
Why do you need a shifter for lego league? You don't need to push and load or any other robot, so high gear will work fine. It is not worth the motor or whatever actuator you are using to shift, as you could use it for an arm or something.
What is shift-on-the-fly about it? The fact that the gears will mesh because they are plastic? It actually wouldn't shift unless the robot is moving.
If you are just building this for the heck of building building it, then thats awsome, and you should ignore this rant.
pic: Gerrish Gearbox MK-III #2 CD47-Bot Extra Discussion 26 12-09-2003 11:35
pic: Gerrish Gearbox MK-III CD47-Bot Extra Discussion 22 04-09-2003 16:32
pic: 3-speed lego geerbox CD47-Bot Extra Discussion 4 14-07-2003 23:42
Shift on the fly LEGO gearbox rlowerr_1 Robot Showcase 17 14-07-2003 23:33
pic: Gerrish Gearbox MKII CD47-Bot Extra Discussion 63 03-07-2003 00:06
