Go to Post It means Dave Lavery isn't on the Game Design Committee this year. If he were, you probably would have found a banana instead. - Alan Anderson [more]
Unread 11-10-2003, 14:15
ajlapp ajlapp is offline
AKA: Anthony Lapp
stuff i explained in other threads
i explained some of these controls and stuff in another thread, but i'll throw it up here for you guys also.
those are drills for the record, and i could show you how to make those omni-wheels, with the right tools they're very simple to build.
check out this video for a look at it in action.
http://stuweb.ee.mtu.edu/~alkrajew/FIRST/kiwi.mpg
CONTROL STUFF
we used three normal joysticks, connected together with a "y"-shaped yoke, and ball joints. the x-axis of each stick was unwired, and the threey-axis of each stick were wired into one coupler.......just to save space on a cramped IO.
so each y-axis of the joystick represents the velocity vector of one wheel. the joystick does the complex task of converting cartesian coordinates to polar coordinats inherently.
the robot goes in the direction the stick is pushed, or spins if the stick is rotated in the center.
the attached pictures show how the joystick is a vector based model of the real robot......instead of a motor and gear set, you have a potentiometer. you manually input the velocity of each motor and the robot responds. (both pictures were prototypes)
problems!
our drivers created what they called slip. this was their method for driving. it was based on a general direction rather than a finite point in space. they kind of glided the robot to its position. the joystick doesn't make it super easy to go in straight lines, but straight is irrelevant when you can go anywhere instantly.
we worked around this by making multiple faces for our robot to operate on......front didn't really matter.
Anthony Lapp
FIRST Engineering Mentor
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
pic: 2002 Team 639 Final Push Semifinals CD47-Bot Extra Discussion 2 31-03-2003 14:05
Disqualifications archiver 1999 13 23-06-2002 21:53
