Go to Post Build season is the best time of the year. Better than Christmas because the presents are cooler, and better than new years cause you get to stay up later. - burkey_turkey [more]
Unread 10-30-2003, 02:03 PM
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
bevel gears...
Berg sells miter gears that can be made to work with the EDU kit.
It will not be pretty but it can be done.
I recommend a 1 to 1 ratio with a relatively small diameter to keep "tilt" from disengaging your teeth ( like the pair M72N-1A for example).
This gear set is aluminum and has a 1/8 inch bore. You will have to make the hole square. To do that, I recommend the following broach from McMaster.com 3156A11 -- the problem is that it costs a bit more than I like -- but I have used it and they are beautiful for making EDU compatible square holes in aluminum parts).
Also, the pitch of these gears is a bit danty (72DP -- that means . You will likely have issues trying to get these gears to stay engaged reliably -- the teeth are only a little more than a half mm tall!)
To be honest, I suppose that for the most part, you could modify something from another toy set (Lego maybe) and have better success.
Good luck just the same.
Joe J.
Thunder Chicken CCT Simon G Motors 4 01-03-2003 01:18 PM
"Motors and Drive train edition" of Fresh From the Forum Ken Leung CD Forum Support 6 01-29-2002 12:32 PM
Drivetrain help thedillybar Technical Discussion 9 01-08-2002 09:54 PM
Drivetrain Help Jordan Technical Discussion 16 12-02-2001 12:14 PM
Drill motor gearBox question Dennis Hughes Motors 4 10-11-2001 07:11 AM
