Go to Post Push the envelope a little, but not too much. There's a difference between being on the cutting edge and being on the bleeding edge. - cadandcookies [more]
Unread 24-11-2003, 09:34
Sachiel7's Avatar
Sachiel7 Sachiel7 is offline
<Yes I managed to flip it
AKA: Shayne Helms
FRC #1132 (RAPTAR Robotics)
Sachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really nice
Send a message via AIM to Sachiel7
Sounds cool.
BTW - If you right-click on the joystick it recenters both axis.
Heh, I just figured that out last night. Helps alot!
I have a few questions though:
What did you use to program this?
I'm trying to understand the communications a bit more. I don't have very much experience in serial or COM communications at all. From what I understand, the PC puts together a data packet of all 4 joysticks. This is 8 bytes in length. I'm assuming it's 2 bytes per joystick, 1 byte per axis. When Its got a new packet ready, it sends out a signal to the RC. When the RC is ready to receive, it sends a signal back. The RC receives the packet, then sends out its 10 byte, 2 integer packet back.
But I'm having trouble with the inner workings of this routine. I browsed through the pc_interface.c file included in the packet, and found the Wait4TXEmpty function call. I noticed that when I tried to compile the project, I couldn't, because the alias.h was referred to as IFI_aliases.h and the IFI_default.h (i think) was missing something. I'm guessing you updated the default code with that function.
Anyway, I'm guessing that it means wait until the PC has pulled this value.
So, when I load up my program (the one I wrote for the joysticks ) and it starts transmitting data, the RC gets stuck in an infinite loop. Now, my PC recognizes if the RC goes offline, so I know it's seeing it right. I just don't think I'm handling everything correctly. Could you give a C code example (even though I'm using Qbasic ...for now...) of how the data's put together and sent/received. Anyway, I have got the joystick input working aok. I've got one flight stick hooked up, and I can pull all the axis, wheel, and buttons from it. The program I have currently calibrates the joystick at startup, then filers the values every cycle, so they range from 0-254, and the axis are lined up correctly. So far so good. I just need an idea of what to do after that. After 1 PC cycle, the next packet is ready. So, I'm supposed to send a small byte to the RC, right? Or do I pull a value?
That's where most of my confusion sets in.
Oh, and another quick question:
What's the setup of the COM connection?
9600baud, no parity, 7 databits, 1 stopbit ?
That also may be where I'm off. Anyway, thank's for the help.
-=Sachiel7=-
There's no such thing as being too simple!
Look for Team #1132, RAPTAR Robotics at the VCU Regional this year!
How much planning goes into your robot? Jnadke General Forum 41 29-01-2006 21:29
White Paper Discuss: Using an Operator Interface with the 2004 EDU RC CD47-Bot Extra Discussion 6 20-01-2004 21:11
Some code in C that we may need if we are in trouble Andrew Rudolph Chit-Chat 16 07-10-2003 21:34
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
Controlling a FIRST robot with a Lego RCX Controller? archiver 2001 5 24-06-2002 04:19
