Go to Post If everyone could just worry about how much fun they are having rather than how much they disagree with other teams, the program would be much better off. - Tom Bottiglieri [more]
Unread 21-11-2003, 16:12
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
pic: Planetary Gearset
Unread 21-11-2003, 16:16
in an automatic transmission like this in a car, there are clutch mechanisms, called bands, that hold one set of gears still, to get the ratio you want to the output
and dont forget, the torque converter in a car is not only a slipping clutch, it is also a form of hydralic CVT itself (its like a backwards CVT - the motor can vary over a range of rpms while the drive wheels are at a constant speed)
You can get more HP out of an automatic transmission off the line, than you can from a standard one (with a clutch) because the auto can rev up to its optimum RPM
very similar to the problem we face with electic motors - to get the most HP they have to be spinning at the midpoint of their RPM range
Unread 25-11-2003, 10:25
Mr. Ivey's Avatar
Mr. Ivey Mr. Ivey is offline
Mark Ivey
AKA: Mark
Mr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of light
Send a message via AIM to Mr. Ivey
Yes, I've been thinking about the bands, there are some possibilities of building a one way clutch, and something I'm working on that I call a limited slipping clutch. It works on the idea that the clutch holds the part still until a certain amount of force is applied, then it starts to slip and and all heck breaks loose, not that this clutch will probably be a one time use device. The other big issue I see at this time is the fact that in an automatic transmission there are pneumatic "breaks". They are what hold the gears in the gearset to get the different ratios. I need to find a way to make something like that to make an efficient gearset.
Ivey
When you tell a student not to do it, you shouldn't do it. Or else you will wind up with a 3/8" drill bit in your finger... Like I did...
Unread 22-12-2003, 01:55
jburstein jburstein is offline
jburstein is an unknown quantity at this point
Re: pic: Planetary Gearset
there aren't pneumatics in any slushbox that I'm aware of--it's called a slushbox precisely because it's hydraulic (well ok, so no it isn't... that's because of the aforementioned power-sucking torque converter. Come to think of it, horsepower isn't the only thing it sucks...).
TCP/IP on a PIC Venkatesh Electrical 1 18-11-2003 21:00
I²C Interface on PIC CBM3 Programming 2 01-11-2003 22:28
pic: Another pic of Team 930 CD47-Bot Robot Showcase 7 25-02-2003 21:07
FYI 'Image Discuss:' is now 'Pic:' Brandon Martus Announcements 0 24-02-2003 12:17
