Go to Post The flux capacitor should have been allowed under the flowchart as long as it met the single component maximum cost. I did check with Digikey and they no longer carry the line. - Al Skierkiewicz [more]
Unread 21-01-2004, 00:38
WakeZero WakeZero is offline
FIRST-a-holic Strategist
#1011 (CRUSH)
WakeZero will become famous soon enough
Send a message via AIM to WakeZero Send a message via Yahoo to WakeZero
Re: pic: Swerve^2 Prototype
Here is what we use to turn ONE set of wheels. We have one of these on the back two wheels, and one on the front. You can't see them in the picture because they are mounted upward, and hidden by the frame
I explained it in the picture description, but that doesn't show up in the discussion. So here it is again
Yes, it does drive on it's own power up the small steps. Right now we have one drill motor driving all four motors, this will eventually be two. To steer we use two globe motors, one for the front wheels and one for the back. This allows us to do two things:
A) Tank-turn by turning the front wheels 180 degrees from the back wheels. This allows us to change the robots orientation easily.
and
B) Change to a car drive mode where only the front wheels turn.
To drive the swerve, right now we have one joystick. In programming we convert the x and y coordinates to polar by using lookup tables. This gives us the angle we want the wheels to face, and then the magnitude for how fast we want to drive.
2004 Arizona Regional -- Semifinalist
2003 NAT Galileo Division -- Highest Seeded Rookie (20th)
2003 NAT Galileo Division -- 100% Autonomous Completion (7 for 7)
2003 Arizona Regional -- Rookie All-Star Award
2003 Arizona Regional -- Quarterfinalist
Alumni on Team 64, The Gila Monsters
College Mentor/Founder of Team 1011, CRUSH
TCP/IP on a PIC Venkatesh Electrical 1 18-11-2003 21:00
I²C Interface on PIC CBM3 Programming 2 01-11-2003 22:28
pic: Team 857 Prototype Killough 2002 CD47-Bot Extra Discussion 19 13-10-2003 08:12
pic: Another pic of Team 930 CD47-Bot Robot Showcase 7 25-02-2003 21:07
