Go to Post Your wheels look delicious. - Alexa Stott [more]
Unread 21-01-2004, 04:56
Engineering Mentor
FRC #0254
Re: pic: Swerve^2 Prototype
Your assumption would be correct for almost all motors in the kit except the globe motor (in my honest opinion).
For some reason (maybe someone knows specifically) the globe motor is VERY sensitive to side loads. In past years when my team used these motors, if the shaft was not supported on both ends we would ruin the motor, even if it was used rarely.
If it is possible (it looks failry easy) you might want to try and put a bearing supporting the shaft on the other end... even though you might not really need it... it seems like it serves an important enough function to deem the extra work beneficial... even if it only gives you peace of mind.
Hope that helps
-Travis Covington
TCP/IP on a PIC Venkatesh Electrical 1 18-11-2003 21:00
I²C Interface on PIC CBM3 Programming 2 01-11-2003 22:28
pic: Team 857 Prototype Killough 2002 CD47-Bot Extra Discussion 19 13-10-2003 08:12
pic: Another pic of Team 930 CD47-Bot Robot Showcase 7 25-02-2003 21:07
