Go to Post All in all, you get what you celebrate. The more we celebrate the under-served parts of our team the more students step up and make that part great. - Alpha Beta [more]
Unread 23-01-2004, 11:42
WizardOfAz's Avatar
WizardOfAz WizardOfAz is offline
AKA: Bill Bennett
FRC #1011 (CRUSH)
WizardOfAz will become famous soon enough
Send a message via AIM to WizardOfAz
Re: pic: Swerve^2 Prototype
Originally Posted by FotoPlasma
Do you think you might be able to post a CAD or two of the wheel modules? I am very interested in how you implemented the coaxial swerve system.
Here's a photo of a pre-season prototype wheel, #0 as it were. Though the new ones have minor improvements (e.g. better spacers), they are essentially like this one.
http://crush1011.wookus.net/pix/2003...lPrototype.jpg
The motive drive comes down the center shaft, through the miter gear pair, then by chain to the wheel. The ratio is 1-1 all the way from the S-B motor up to the last sprocket, where it gets geared down by 1-2.8 (10 to 28 tooth sprocket). The vertical shaft is spinning in and supported by a half inch bore in the large teflon bushing.
The steering drive comes in the big sprocket on top. That sprocket is bolted through the large teflon bushing to the top plate of the yoke. Steering is accomplished by turning the teflon bushing in the top plate. The top plate mounts to the robot frame. The steering drive is also a 1-2.8 geardown, using the globe motor.
For size reference, the top plate is 6"x6". The large teflon bushing is 3" OD with a 3/8" groove where it rides in the top plate. The teflon splits in two pieces within this groove in order to make assembly possible.
We have some CAD drawings, but a few changes were made to the design post-CAD. Hopefully this picture makes it all reasonably clear. If not, please ask.
This system is not without its challenges, but we're working through them. First, it's a lot of gears and chain, and resulting end-to-end losses. Second, there is some coupling from the motive drive to the steering drive, which makes good steering tracking code more important.
It's very fun working on it though [;-)
Bill
TCP/IP on a PIC Venkatesh Electrical 1 18-11-2003 21:00
I²C Interface on PIC CBM3 Programming 2 01-11-2003 22:28
pic: Team 857 Prototype Killough 2002 CD47-Bot Extra Discussion 19 13-10-2003 08:12
pic: Another pic of Team 930 CD47-Bot Robot Showcase 7 25-02-2003 21:07
