Re: Code Repository
The reason why I think that full "ready-to-run" programs should not be uploaded to a repository because it encourages copy-paste. Yes, a big part of FIRST is learning from others. But a just as important part of FIRST is learning from discovery. |
Re: Code Repository
That is what I was kind of getting at for the idea about the repository. It took me a long time to figure out how to integrate the yaw rate sensor signal. Every place I looked did not have one example on how to do it. Granted I figured it about after about 12 hours of fustration. It just would make me wonder how long some of the other programers (minions) on my team might have taken.
Re: Code Repository
I'm currently implementing a repository at:
http://nrg.chaosnet.org/repository Spread the word! Note: it is not finished, I'm working on it. And, you HAVE to register an account at the NRG website to be able to post code to the repository. Hope you like it! |
Re: Code Repository
well, i would go add my demo trig table code, but the register/login feature does not work yet, apparently. looking like it's going to be nice when it does, though!
Re: Code Repository
Click "Register." Then enter the info into the fields. Click register. Then login using your username and password. |
Re: Code Repository
i get an http 404 when i click on the initial "Register" button.
Re: Code Repository
Re: Code Repository
it seems that your form is currently pointing to "/repository/slogin.php", while the file is at "/uploads/slogin.php" - this probably isn't what you want. (note - the login form doesn't work either, same error message.
Re: Code Repository
I'm using the <base href="../uploads/"> tag to point to the correct page. Is that supported?
#10
Re: Code Repository
deltacoder,
how did you finally successfully register and login? |
#11
Re: Code Repository
don't depend on it - it's better to hard-reference all of the links. the BASE tag is nowhere near supported on all pages. also, it's good practice to quote all of the attributes for a tag, not just those with spaces.
i registered and logged in on the main page for the team, then switched over to the repository (at least the session carried over) Last edited by deltacoder1020 : 01-25-2004 at 05:34 PM. |
#12
Re: Code Repository
Re: Code Repository
Re: Code Repository
Exactly what do you click on? (the whole trail)
'cause it works when I'm not logged in. (And I was working on it when you saw it, it's fixed now). I'm starting a seperate thread for the NRG code repository specifically. Last edited by SilverStar : 01-25-2004 at 06:03 PM. |
#15
Re: Code Repository
Okay. An issue of timing, then. It seems to work fine now. Good work
| What is your most prefered programming language? | Hailfire | Programming | 156 | 01-19-2005 09:42 PM |
| InfraRed autonomous code ... | mtrawls | Programming | 1 | 01-11-2004 12:25 AM |
| Autonomous code | PBoss | Programming | 7 | 01-14-2003 03:29 PM |
| Does your team use the Default code. | Jeff McCune | General Forum | 2 | 01-09-2003 02:46 PM |
| Patent source code? | Kyle Fenton | Chit-Chat | 3 | 10-20-2001 05:53 PM |
