Go to Post bump. - connor.worley [more]
Unread 01-25-2004, 10:55 PM
tkwetzel's Avatar
tkwetzel tkwetzel is offline
Good Luck Teams!
AKA: Tyler Wetzel
FRC #0116 (Epsilon Delta)
tkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond repute
Send a message via AIM to tkwetzel
Re: White Paper Discuss: Dual-motor, dual-speed gearbox
The correct gear for the bosch output shaft is a 55 tooth gear.
I do not see the inconsistency with the shaft location holes that you mention. I do not believe that there is any inconsistency. BTW, this design has worked well for us in the past, so it should not have any major problems, there just might be some improvements to the design.
See you in DC!
White Paper Discuss: Dual Motor Gearbox - 2003 CD47-Bot Extra Discussion 6 04-08-2004 07:46 PM
White Paper Discuss: 2 speed, Shift-on-the-fly TechnoKat Gearbox CD47-Bot Extra Discussion 35 01-23-2004 08:16 PM
Some code in C that we may need if we are in trouble Andrew Rudolph Chit-Chat 16 10-07-2003 09:34 PM
pic: dual speed gearbox CD47-Bot Extra Discussion 9 10-07-2003 03:04 PM
