Go to Post With CD down... I wasn't sure what to do with my free time. I almost had a reality check and thought I might go outside. - Barry Bonzack [more]
Unread 02-02-2004, 19:17
Frank(Aflak)'s Avatar
Frank(Aflak) Frank(Aflak) is offline
#1067 (SLUH)
Frank(Aflak) is on a distinguished road
Re: pic: TEAM 1213 GROVES HS
Originally Posted by Andy Brockway
What gear ratio are you using between the CIM and drill? Drill in low is at 450 rpm and the CIM is at 5000(?) rpm. This is greater than 10:1, not matching close will cause one motor to add inefficiencies to your system. Of course your robot looks pretty light right now so this is not a big concern right now.
As you add systems the inefficiencies will show up in battery drain. Possibly a big factor at the end of a match.
I love the picture of your robot climbing the cabinet! Add an anti-gravity unit and you will get up on top!
I think that it is in high gear. Makes sense that way. They will have a FAST robot.
Anywho, check out their drill motor mount!
Already broken, thats gotta be a new record.
Get a new one or fix that one, your drive base looks great. Lightweight, FAST, durable (well, it looks durable, anyway). Compact. A good job.
Best of luck!
"Relationships are alot like those little packages of condiments you get at fast food resturants -- they're these little magical things that can last forever on a shelf, but once you open them up, they go bad really fast. I just don't understand condiments."
-- Jim, from "Lily & Jim" by Don Hertzfeldt
Disqualifications archiver 1999 13 23-06-2002 21:53
