Go to Post FIRST is not a party. It is the most important activity a high school age student can do. - JohnBoucher [more]
Unread 03-02-2004, 16:36
rlowerr_1's Avatar
rlowerr_1 rlowerr_1 is offline
#0930 (M³)
rlowerr_1 is an unknown quantity at this point
Send a message via AIM to rlowerr_1
Re: pic: 2004 chassis 930
Ok, seeing as I posted the picture I guess it’s only fair that I answer some of your questions.
All extrusion in the picture, excluding the bearing blocks, are item profile 5 20x20. The bearing blocks are item profile 5 20x80.
The only t-nuts used are to hold the ‘belly pan’ to the bottom of the chassis. All the rest are what are called standard fasteners (see picture).
For the bearing blocks we tapped the ends of the extrusion and milled clearance holes for M5 screws that go through the 20x20. This eliminates the problem that we see many teams facing each year with their pillow blocks shifting around on them. This also allows us to easily remove the bearing blocks if repairs are needed by simply taking out the four screws that hold them in place.
We weighed everything you see in the picture above at just over 20 pounds.
Ryan Lowerr - Ryan@lowerr.com
Check out my LEGO creations here!
pic: Team 190 Chassis and Driveline CD47-Bot Robot Showcase 1 01-02-2004 01:57
2004 edu controller (PIC) is out! caffel General Forum 13 09-10-2003 23:02
pic: The Full 2004 RC?! CD47-Bot Extra Discussion 7 07-10-2003 17:19
pic: 2004 Game Revealed! CD47-Bot Extra Discussion 28 12-09-2003 12:08
pic: Another pic of Team 930 CD47-Bot Robot Showcase 7 25-02-2003 21:07
