Go to Post When motors stall, bad things happen. - Rob Stehlik [more]
Unread 06-02-2004, 22:45
Yan Wang's Avatar
Yan Wang Yan Wang is offline
Ithaca is Gorges
AKA: John Wayne
FRC #0639 (Code Red Robotics)
Yan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud of
Send a message via ICQ to Yan Wang Send a message via AIM to Yan Wang Send a message via MSN to Yan Wang Send a message via Yahoo to Yan Wang
Re: pic: 639 Vertical Adjustment Rover
Originally Posted by Elgin Clock
It technically is legal, just not in the way you are thinking.
That's all I am saying, think outside the box.
You'll see what I mean soon enough!
Er... I suggest you run all VAR-like designs through FIRST before construction. I don't think they want anyone remotely messing with the vertical bar.
Q: <T04>: Robots can't attach to the vertical bars - this would cause damage with a 130lb bot. However, is it ok to use a rover/tether device 5-10lbs in weight to climb up the pole, attach a hook, and then detach from the pole?
A: No.
Code Red Robotics Team 639 Alumnus | www.team639.org
<Patrician|Away> what does your robot do, sam
<bovril> it collects data about the surrounding environment, then discards it and drives into walls
Unread 06-02-2004, 22:51
Elgin Clock's Avatar
FRC #0237 (Black Magic)
And like I said, "Think outside the box."
It can be done with no rules being broken or even bent, just think about it for a minute or two, and you may be able to see what i am talking about!
V = no
H = yes
Unread 06-02-2004, 23:06
Aaron Knight's Avatar
Aaron Knight Aaron Knight is offline
McWebmaster du Pi
None #0891 (Neverending Chaos...)
Aaron Knight has a spectacular aura aboutAaron Knight has a spectacular aura about
Send a message via AIM to Aaron Knight
V = no
H = yes
Coulda misinterpreted it, but isn't the point of the design to be vertical? You can't touch the vertical bar......
If you're implying attachment to the horizontal bar from the side of it....maybe, but that sounds kinda unlikely to me. You'd have a hard time getting the leverage.
Aaron Knight
Mentor, Team 891: Neverending Chaos...
Behold the Power of PI
Syracuse, NY
email: acknight@syr.edu
aim: akacomputerboy, farktal891
http://www.neverendingchaos.com
DOX, The Un-official FIRST Frat
Unread 07-02-2004, 00:16
ahecht's Avatar
ahecht ahecht is offline
'Luzer'
AKA: Zan
ahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond repute
Send a message via ICQ to ahecht Send a message via AIM to ahecht Send a message via Yahoo to ahecht
What he is talking about is an idea that we passed on during brainstorming. That device would be used on the horizontal bar to allow your robot to move side to side as it is hanging, perhaps to block your opponent from latching onto the bar.
Zan Hecht
Scorekeeper: '05 Championship DaVinci Field/'10 WPI Regional
Co-Founder: WPI-EBOT Educational Robotics Program
Alumnus: WPI/Mass Academy Team #190
Alumnus (and founder): Oakwood Robotics Team #992
"Life is an odd numbered problem the answer isn't in the back of the book." — Anonymous WPI Student
Unread 07-02-2004, 00:19
Wow you guys are good!! A few people caught my misinterpretation of the wording. Sorry, I didn't realize it was called a VAR - just the concept I was referring to!
Yes, what I am talking about is what ahecht is describing! Thank you for clearing it up for me!
Unread 09-02-2004, 22:54
patrickrd's Avatar
patrickrd patrickrd is offline
AKA: Patrick Dingle
patrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to behold
Send a message via AIM to patrickrd
Yan deserves an awful lot of credit for coming up with this idea, it's definately one of the original ideas I've seen in some time. Upon one of my weekly visits to the high school to see the progress of the robot, Yan showed me a sketch of this idea. Some of my original questions were:
"Is that legal?"
"How is that supposed to lift 130 lbs???"
Anyway, after at least a half hour of pressing the idea on me (it took me about this long for me to understand the principle concept involved), he finally convinced me that it would work, and then shortly after that I became convinced it would have been the coolest mechanism I've ever seen on a FIRST robot. So I helped him work on the design, pointed out that you need omniwheels in order to make it work, and another college member of the team pointed out that you can make it work spring-loaded, without need for a third actuator. So we drew up this model... Unfortunately, it is illegal The only problem I can see with it is that there is a slot milled out of the vertical bars allowing the horizontal bar to move up and down in between matches, which may screw up the omniwheels in this device, but I'm sure that they could be optimized to work even given the slot.
I think it would be really sweet to make one of these devices that is battery powered (4 Lithium-Polymer batteries would work well and is the size of a cell phone), and controlled using radio.
Anyway, awesome idea Yan. I'm definately available to help work on it for kicks and giggles it if you'd like to. Not sure where I'll find the time......... But..... Too cool to pass up.
- Patrick
Systems Engineer - Kiva Systems, Woburn MA
Alumni, Former Mechanical Team Leader - Cornell University Robocup - 1999, 2000, 2002, 2003 World Champions
Founder - Team 639 - Ithaca High School / Cornell University
Alumni - Team 190 - Mass Academy / WPI
pic: Team 639 Front Omniwheel CD47-Bot Robot Showcase 16 19-05-2004 23:02
pic: Team 639 Robot Before Ship CD47-Bot Robot Showcase 11 31-03-2003 21:35
pic: 2002 Team 639 Final Push Semifinals CD47-Bot Extra Discussion 2 31-03-2003 14:05
