Re: pic: Team 710 Drive module
My guess would be that those modules themselves actually rotate. Put down the slick wheels for turning, the beefy ones for pushing, and rotating them climbs the step too. We considered something similar to this, but decided against it for weight reasons.
you could mill a TON of weight out of that aluminum plate, maybe on all 4 you could remove a lot of it and be able to put all 8 original wheels back in. just a suggestion
Ya we thought about takin out some pieces. Those two-wheel module weigh about 6.7 lbs and the other ones weigh only 6, only problem is we don't have much time to take and mill out some weight and the structural integrity of those is really important
I don't disagree we could use some weight. But when it comes down to it.. its not really a ton It was barely noticeable Last edited by Dan Richardson : 04-03-2004 at 00:47. |
Think about bridges, for example. Trusses support immense load, yet they're largely open space. Cutting a similar pattern of triangles into plates such as yours is often an effective way of reducing weight while maintaining strength. |
it's amazing how simalar those are to ours.....
EDIT: Picture link above fixed now. Last edited by sanddrag : 04-03-2004 at 01:20. |
From what i have seen you guys 73, us 710, and 258 have a similar design with the "gurney" style drive.
fixed
#10
Well except for the fact that have a considerable amount of spacers running through the centers where these designs would be cut out. And we did run into problem withs spherical our cuts weakening the system. Infact the forks we milled where the only ones we had problems with
I was not saying that it couldn't be done. I was saying that the difference in the weight made is basically nothing. its 3/16th alluminum and we could cut out a max of about 1x2 inches. Weighing only a few grams. ( to be exact its about 0.0360 lbs per piece ) If it had been better designed in the beggining when those parts were designed it could have been designed with the cut outs inplace. But with our current system it can not be done with enough effectiveness to cause reason to do it. But again, the extra work done on it, and the weight gained we felt were too minute to deal with under our certain time restraints. THanks for the advice tho keep it coming Dan ps. see our bot in action ( sorry for bad editing job, I'll be re-editing this weekend hopefully ) View Us Our forks in action Us hanging because of our lifting system Last edited by Dan Richardson : 04-03-2004 at 00:49. |
#11
Heres a lower resolution vid (5MB as compared to 25MB)
Low Res 710 Video ps .avi's soon to come if this one doesn't work (people have told me that it won't work on their computer.) |
#12
that is very cool....we only use ours on the back of our robot and have an omni wheel bar that comes down and suppports the front...i really like the automation of the system...what are you using for the feedback... limit switches?
i like it and look forward to seeing this bot inaction |
#13
Thanks!
We use banner sensors, one in front of each wheel. The way it is set up is that when one of the sensors gets over teh step it pulls either the front or the back up. The driver controls if the banner sensors are activated or not with the trigger button on the joystick. I think you can see the banners in one of our posted pics. One thing we have to do at comp is reset the banners to the hdpe on the step. Works well for the most part and takes one thing out of the driver's hands (not that me and dan couldnt do it )Last edited by abeD : 04-03-2004 at 01:12. |
#14
Greg, as abeD said earlier, we're doing the same type of drivetrain. We are going to be using limit switches for feedback. We considered using other kinds of proximity sensors, but due to time and money constraints, we chose to go with the limit switches we had lying around the lab.
How about you guys? |
| pic: Team 60 Drive Train Parts | CD47-Bot | Robot Showcase | 17 | 07-02-2004 01:58 |
| The 2003 Index of team's post about their robot... | Ken Leung | Robot Showcase | 4 | 28-02-2003 00:18 |
| pic: Team 870 Rear Drive Train | CD47-Bot | Robot Showcase | 2 | 27-02-2003 00:22 |
| pic: Team 980 "Thunder Bot" drive train | CD47-Bot | Robot Showcase | 12 | 25-02-2003 14:02 |
