Go to Post I also like how the FTC folks are able to get involved with the FRC process this year, but it's always a bit of a let down when you're told you can't launch things into the air. - s_forbes [more]
Unread 08-02-2004, 22:29
781admin's Avatar
781admin 781admin is offline
None #0781 (Kinetic Knights Team 781)
Team Role: Webmaster
781admin is an unknown quantity at this point
Re: pic: 781 - Teaser1
Water Cutter.
Unread 08-02-2004, 23:23
tkwetzel's Avatar
tkwetzel tkwetzel is offline
Good Luck Teams!
AKA: Tyler Wetzel
FRC #0116 (Epsilon Delta)
tkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond repute
Send a message via AIM to tkwetzel
DO you have that equipment in-shop or is it done elsewhere?
See you in DC!
Unread 09-02-2004, 02:19
That is really really nice. BUT, if someone comes and rams into your fender bending it into the wheel, you are done for the match.
Unread 09-02-2004, 04:25
Lord Nerdlinger Lord Nerdlinger is offline
Lord Nerdlinger has a little shameless behaviour in the past
I got nothing to add
but wow that's intense
are all the bearing holders and gear slots, (etc) for the wheels milled into that so that the whole drive train with all teh components is one solid peice?? Cuz that would be super cool.
We have a mill but we suck at using it, we couldn't make anything that quality
Unread 11-02-2004, 14:47
Josh Fritsch's Avatar
Josh Fritsch Josh Fritsch is offline
Team 27 Mentor/Alumni
FRC #0027 (Team Rush)
Josh Fritsch has a spectacular aura aboutJosh Fritsch has a spectacular aura about
That looks amazing, im guessing you had it water-jetted, if not, very nice job on whoever machined it. The only think is that it looks heavy. How think are those plates?
Unread 11-02-2004, 15:20
Rhs953's Avatar
Rhs953 Rhs953 is offline
Revenge is near...
AKA: Mike
#0953 (Illumanati)
Rhs953 has a little shameless behaviour in the past
Send a message via AIM to Rhs953
WOW
That is incrediable!
___________________________
If all else fails, use a bigger hammer.
Unread 11-02-2004, 21:55
Heero195's Avatar
Heero195 Heero195 is offline
Alum
AKA: Megan
no team (Kinetic Knights)
Heero195 is an unknown quantity at this point
Send a message via MSN to Heero195
Originally Posted by OneAngryDaisy
How.in.the.earth?
did you guys machine that yourself? water jetted? it's just.. eh... so... pretty and perfect..
One of our mentors is a machinist, so he water jetted it for us.
Unread 12-02-2004, 19:44
scifi3018 scifi3018 is offline
scifi3018 is an unknown quantity at this point
wow, wow, wow, wow, if only we had that kind of resources, i had to fight our mentors tooth and claw to try and convince them to use trick wheels, but in the end, i lost
TCP/IP on a PIC Venkatesh Electrical 1 18-11-2003 21:00
I²C Interface on PIC CBM3 Programming 2 01-11-2003 22:28
Learning PIC C Adam Collet Programming 18 19-10-2003 19:36
pic: Another pic of Team 930 CD47-Bot Robot Showcase 7 25-02-2003 21:07
