Go to Post Good Luck all - this one will hurt your brain, but it's all in a good way. - meaubry [more]
Unread 12-02-2004, 10:03
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
pic: Team 968's robot... Kinda
Unread 12-02-2004, 10:06
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: pic: Team 968's robot... Kinda
Whoever had to weld that mustve been happy
That scale looks a lot like the one we were using. I wouldnt doubt that that all is 47 lbs, but the scale we were using said that our prototype bot we made in the last few months weighed in at 135 lbs, when it was really 110 lbs. We got some weights from our weight room and found that the weight almost varies exponentially.
Basically, you might want to be careful using digital scales, or go to the post office and weigh something, then come back and compare it to whatyou get on your scale.
Cory
2001-2004: Team 100
2006-Present: Team 254
Unread 12-02-2004, 10:14
Alavinus's Avatar
Alavinus Alavinus is offline
Siege Weapon/Robotics Guy
AKA: Andrew LaVinus
Alavinus will become famous soon enoughAlavinus will become famous soon enough
Send a message via AIM to Alavinus
Was your scale completely 100% absoutely level? It seems they are using a scientic balance instead of your average run of the mil scale. In my experience, these scales must be on a firm surface and completely level before you weigh, otherwise you'll get garbage.
Onto the real thread= Nice robot. Our team wanted to weld, but the me being the cruel mentor that I am wanted to have the flexibility to add in extra frame parts.
Unread 12-02-2004, 14:34
Engineering Mentor
FRC #0254
We just purchased this scale a few days ago, and so far it seems to be accurate (measuring things of known weight)
The scale *says* it is accurate to within .5lbs, and we have determined that it is close enough for our purposes. In this picture, the robot parts were centetred, and the scale was level.
As far as the welding goes, we were lucky to have a local company donate their time and help us weld some of it. The parts you see took about 11 hours to weld in total, spread across a few days (one being almost 7 hours in itself!)
-Travis Covington
Unread 12-02-2004, 14:44
Collin Fultz's Avatar
Collin Fultz Collin Fultz is offline
no team (IndianaFIRST)
Collin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond repute
so what does it do? it looks like it may be a little ball pusher...or i could be dead wrong.
Collin Fultz
Unread 12-02-2004, 14:56
Dan Richardson's Avatar
Dan Richardson Dan Richardson is offline
iR3 Creative
AKA: Dan Richardson
Dan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond repute
did you weld your pnuematic cylinder to your frame.. I mean I could be mistaken but, it sure looks like you did.
And if you did.. Is that legal? ... or Safe?
CO-Founder of Robot in 3 Days and the Robot in 3 Day Challenge.
Unread 12-02-2004, 15:01
it looks like there is an extension from a pipe out to the nu-matic and it is bolted on.
Collin Fultz
Unread 12-02-2004, 15:13
Engineering Mentor
FRC #0254
No, it is not welded. If you look closely you can see a bolt sticking out from the bottom of where the piston mounts to.
Also, ball pushing is a good guess! That's only a SMALL part of it though.
-Travis Covington
How much planning goes into your robot? Jnadke General Forum 41 29-01-2006 21:29
pic: A Side View of Team 898's robot CD47-Bot Robot Showcase 2 07-03-2003 03:05
about how Drive Train push the robot... shouldn't the force accelerate the robot? Ken Leung Technical Discussion 12 26-11-2001 09:39
