Go to Post Regardless of the next course of action, getting steamed and angry will benefit nobody. And coming from me, that has to mean something. - Lil' Lavery [more]
Unread 16-02-2004, 11:45
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
pic: Team 188 Teaser 2
Greg Perkins's Avatar
7 years, allready!!???!?!?!
AKA: Mongo
Re: pic: Team 188 Teaser 2
Its A Winch!
Unread 16-02-2004, 11:48
David Kelly's Avatar
David Kelly David Kelly is offline
A Legacy of Impact
FRC #0234 (Cyber Blue)
David Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond repute
Send a message via AIM to David Kelly Send a message via Yahoo to David Kelly
Originally Posted by CD47-Bot
Thread created automatically to discuss this image in the Picture Gallery.
Holy cow, cool looking. Only thing that really jumps out is the such small size of that shaft and bolt holding the thing on. I'd think that would likely sheer off really easily. You might want to look into putting a larger on on there.
2010 Indiana Robotics Invitational Planning Committee
2010 Boilermaker Regional
Chairman's Award, Regional Finalist
2010 Kansas City Regional
Entrepreneurship Award
2010 Championships
Autodesk Inventor Award Winner
Unread 16-02-2004, 12:01
ngreen ngreen is offline
AKA: Nelson Green
FRC #1108 (Panther Robotics)
ngreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant future
It's the van door motors shaft (the longer one). We lifted 128 pounds (4 cement brick) running a winch on the shaft with that motor. And we did it w/out supporting the shaft. You won't sheer that. A better nut perhap, nylon locking.
Unread 16-02-2004, 12:12
Bob92 Bob92 is offline
Bob92 is on a distinguished road
A little info on shear ratings
Shear Capacity Calculation
To roughly calculate the ultimate single shear capacity of a bolt, multiply bolt area at full shank diameter times ultimate shear strength rating, e.g. 8-32 18-8 stainless steel bolt, 0.164" diameter. (A standard 8-32)
Area = πr2; 3.1416 x 0.082" x 0.082" = 0.0211 square inches
Single shear = 90,000 psi x 0.021 = 1890 lbs. at full diameter
This calculation is for shearing a 8-32 on the thread. I am pretty confident it will hold your robot.
Unread 16-02-2004, 12:51
Matt Adams's Avatar
Matt Adams Matt Adams is offline
b(o_o)d
FRC #1525 (Warbots)
Matt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond repute
Send a message via AIM to Matt Adams
Post Re: pic: Team 188 Teaser 2
Consider that bolt not flush against the load.. such as a tiny "negligible" bending moment of only .25 inches....
Stress = M * y / I
Stress = M * y / I
130 lbs * .125 * .082 in / (3.141 * .164^4/64) = 75,500 PSI
Compound that with some shear stress... you're in a danger zone. Consider and extra load of an extra robot hanging with you... eek! In my opinion.. using a #8 bolt is definitely pushing a reasonable factor of safety.
However, the van door motor, being 11mm or so, should work out to be just fine.. but I'd definitely try to avoiding doing anything cantilevered... that freaks me out. Keep in mind that those bearing are bought from the cheapest bidder...
Nevertheless, good luck!
Matt
Matt Adams - Engineer at Danaher Motion
Team 1525 - Warbots - Deerfield High School
Unread 16-02-2004, 13:57
Stress = M * y / I
Stress = M * y / I
Matt
I doubt that there is a .25 inch gap. I assume this because most team dont manufacture parts like that to within 250 thousandths. I believe if there was "a tiny "negligible" bending moment" it would only be that of 1-2 thousandths. Especially considering that the nut on the end would hold it all flush.
Unread 16-02-2004, 14:06
That's a cool winch drum but it looks liek it would be really heavy.
Unread 16-02-2004, 14:54
Steve W Steve W is offline
Grow Up? Why?
Steve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond repute
Too heavy. It's at the shop being turned down. We thought 3/4 inch was a little too sturdy.
We do not stop playing because we grow old;
we grow old because we stop playing.
Unread 16-02-2004, 19:21
JoeXIII'007's Avatar
JoeXIII'007 JoeXIII'007 is offline
Pragmatic Strategy, I try...
AKA: Joeseph Smith
FRC #0066
JoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond repute
Send a message via AIM to JoeXIII'007
Nice pulley or winch. The device has a good chance of working, depending on the stress put on the wire.
Unread 16-02-2004, 20:44
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
Such high praise!
Careful, or you might end up actually making a compliment.
188 - Looks awesome guys. I can't wait to see the finished version.
JVN
Unread 16-02-2004, 21:39
jonathan lall's Avatar
jonathan lall jonathan lall is offline
FRC #2505 (The Electric Sheep; FRC #0188 alumnus)
jonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond repute
Send a message via MSN to jonathan lall
I'll give you a bit more.
Yes it's a pulley/winch system. Yes it will hold. No it's actually not that heavy, but we want it lighter anyway. Yes, it backdrives, but not for long. You will be more impressed when you see some other stuff, I promise. That is, if our robot sheds some pounds.
pic: Team 188 CD47-Bot Robot Showcase 4 17-03-2003 16:39
pic: Team 188 CD47-Bot Robot Showcase 5 03-03-2003 17:42
